Home > Td5 > Help - Lights out!
Page 2 of 2 <12
Iain Defender
United Kingdom 2000 Defender 110 Td5 CSW Rutland Red
Thank you!
I think I need to give up for today as to cold and dark.
Hopefully there is an easy test to do tomorrow to find this annoying problem!
Post #694469 18th Mar 2018 6:51pm
4RF RDS
I believe that there is a fusable link under the seat for lights #14 I think. Check that as well. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #694555 19th Mar 2018 1:40am
Iain Defender
So the problem appears to be a damaged orange block above and behind the fusebox near the gear stick.
Problem is how do i get to it to fix it as i have air conditioning!
Help......
Post #696719 28th Mar 2018 12:54pm
4RF RDS
Expose the fuse panel (by removing the cover). Undo the two philips screws holding the fuse panel to the bulkhead. Remove the defective relay, replace and test the sytem. Then reinstall the two screws, fuse cover and you are done. 👍 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #697444 31st Mar 2018 1:48pm
Iain Defender
Found the problem!
Dash out managing to disconnect the air con Smile
Found this blue connector with a burnt out bit, cleaned it, dash back in.
All done in three hours, very pleased no just hope it lasts.
Would it burn out due to brighter bulbs being used as it happned not long after bulb upgrade.
Post #699586 9th Apr 2018 2:25pm
4RF RDS
Have you installed a boomslang style headlight wiring loom? This puts relays to the lights and takes the load off the OEM wiring harness as well as the switch. It also increases the headlight brightness a bit. Well owrth it if you have not sone so. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #699587 9th Apr 2018 2:33pm
MalteseRover
Malta
following Smile
now that i have just changed the main headlight switch. slightly burnt.
thanks a lot.
Joseph
Post #703692 27th Apr 2018 9:45pm
lightning
Are the side lights working in position 1 of the switch.
When you switch to position 2 (headlights) do the side lights stay on or go out?
Post #703696 27th Apr 2018 10:51pm
Page 2 of 2 <12
