Home > Td5 > Help - Lights out! |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 943 |
I believe that there is a fusable link under the seat for lights #14 I think. Check that as well. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
19th Mar 2018 1:40am |
Iain Defender Member Since: 18 Mar 2018 Location: North Posts: 11 |
So the problem appears to be a damaged orange block above and behind the fusebox near the gear stick.
Problem is how do i get to it to fix it as i have air conditioning! Help...... |
28th Mar 2018 12:54pm |
Expose the fuse panel (by removing the cover). Undo the two philips screws holding the fuse panel to the bulkhead. Remove the defective relay, replace and test the sytem. Then reinstall the two screws, fuse cover and you are done. 👍 2010 Range Rover MkIII Autobiography Super Charged (Idris)
31st Mar 2018 1:48pm |
Found the problem!
Dash out managing to disconnect the air con Found this blue connector with a burnt out bit, cleaned it, dash back in. All done in three hours, very pleased no just hope it lasts. Would it burn out due to brighter bulbs being used as it happned not long after bulb upgrade. Click image to enlarge |
9th Apr 2018 2:25pm |
Have you installed a boomslang style headlight wiring loom? This puts relays to the lights and takes the load off the OEM wiring harness as well as the switch. It also increases the headlight brightness a bit. Well owrth it if you have not sone so. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
9th Apr 2018 2:33pm |
MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137 |
following
now that i have just changed the main headlight switch. slightly burnt. thanks a lot. Joseph |
27th Apr 2018 9:45pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2876 |
Are the side lights working in position 1 of the switch.
When you switch to position 2 (headlights) do the side lights stay on or go out? |
27th Apr 2018 10:51pm |
