Home > Series Land Rovers > Is this everything I need to replace the door tops on a SIII
Stacey007
Hello
Does this look right,m apart from maybe 4 rivets for the catch?
Thanks
Post #693202 14th Mar 2018 8:48am
keith
Looks about right mate .
Are they Rocky Mountain replacements
Make sure you put top-bottom seal on the right way around
Keith
Post #693204 14th Mar 2018 9:01am
Stacey007
SP parts
Apparently better than most of the others but not as Pricey as Rocky Mountain Smile
Thumbs Up
Post #693207 14th Mar 2018 9:13am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I replaced mine with the same Scott,
All good quality, also helps to spray some cavity wax inside the door top. Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #693223 14th Mar 2018 10:11am
shayes
United Kingdom 1998 Defender 90 300 Tdi HT Coniston Green
I got these as part of the series door conversion kit for my defender. Good product. I also got some of the smaller stuff I needed on the build u from John Richards surplus (on the web), eg nuts, bolts, seals and other sundries. Have a look at their site. They also do the Wolf door tops (Aly) from time to time. Good source for sundries and other hard to get bits.
Cheers,
Simon Very Happy
Post #693229 14th Mar 2018 10:52am
JMG
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Stornoway Grey
I need to get these as well, who are SP parts ?
Post #693969 17th Mar 2018 9:19am
ian series 1
https://www.sp-4x4.com/
Post #693981 17th Mar 2018 10:00am
Stacey007
Ordered and should be with me on Tuesday Very Happy
Hope the old ones come apart?
Any advice spray lots of wd40 and hope Thumbs Up
Post #694112 17th Mar 2018 6:36pm
ian series 1
Mine were stuck together good and propper,
I don’t think they had ever been apart from the day it left the factory?
Give it a good soaking around the nut, and keep repeating, while gently tapping it upwards,
It will give up eventually Wink 80" 80" 86" 88" 90"
Post #694133 17th Mar 2018 7:43pm
