![]() | Home > Series Land Rovers > Is this everything I need to replace the door tops on a SIII |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2217 ![]() ![]() |
Looks about right mate .
Are they Rocky Mountain replacements Make sure you put top-bottom seal on the right way around Keith |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3758 ![]() ![]() |
SP parts
Apparently better than most of the others but not as Pricey as Rocky Mountain ![]() ![]() |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I replaced mine with the same Scott,
All good quality, also helps to spray some cavity wax inside the door top. ![]() Wanted, Forward Control Anything considered. |
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 ![]() ![]() ![]() |
I got these as part of the series door conversion kit for my defender. Good product. I also got some of the smaller stuff I needed on the build u from John Richards surplus (on the web), eg nuts, bolts, seals and other sundries. Have a look at their site. They also do the Wolf door tops (Aly) from time to time. Good source for sundries and other hard to get bits.
Cheers, Simon ![]() |
JMG Member Since: 16 Apr 2014 Location: Surrey Posts: 222 ![]() ![]() ![]() |
I need to get these as well, who are SP parts ?
https://www.sp-4x4.com/
Ordered and should be with me on Tuesday
![]() Hope the old ones come apart? Any advice spray lots of wd40 and hope ![]() |
Mine were stuck together good and propper,
I don’t think they had ever been apart from the day it left the factory? Give it a good soaking around the nut, and keep repeating, while gently tapping it upwards, It will give up eventually ![]() Wanted, Forward Control Anything considered. |
