Home > Camping, Caravanning and Holidays > Charging vehicle from electric hookup
cartoonhead
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Corris Grey
I will be overlanding my 130 and spending fairly extended periods of time in campsites. I would like to be able to hookup to the available electric similar to the way caravans do, am I correct in thinking that all I need for this is:
- a camping power cable to 3 point mains socket cable (sorry I don’t know the proper names!)
- a smart battery charger permanently plumbed in to the battery, like https://www.alpha-batteries.co.uk/12v-10a-...DMQAvD_BwE
Seems too easy! What am I missing here Embarassed
Post #691345 6th Mar 2018 7:25am
BigRuss
I don’t know if you are missing anything, a friend of mine has and American yacht and to charge the batteries when I’m the uk he plugs the shore power into a uk spec (volts/hz’s) socket the feeds a battery charge rated for it, which in turn charges the 12v batteries in the boat. Russell
2011MY 110 XS USW Black
Post #691347 6th Mar 2018 7:33am
That is how caravans do it, easy as that.
Post #691361 6th Mar 2018 8:58am
Hendrix
England 2013 Defender 110 Puma 2.2 USW Santorini Black
No thats it. I use a CTEK charger but same idea. Look for a charger with more power than required just for your batteries, particularly if you are running a fridge in hot conditions. Go for a cable with the round blue mains connectors as this is used by a high proportion of European campsite but you will need some adaptors for the ones that dont use them, a common issue in the less developed areas. Depending on your travel plans if power is critical you may need 2 cables. At some sites the power can be a good distance away but one big cable can be cumbersome for most places.
Post #691364 6th Mar 2018 9:14am
cartoonhead
Fantastic news - thanks all Very Happy
Post #691386 6th Mar 2018 10:40am
camelman
I've got a shore power socket fitted to the 130 and a CTEK charger connected to it in the battery box.
As soon as I connect up, I've got 240v and the batteries are being charged.
Post #932141 2nd Dec 2021 9:35am
Mo Murphy
Hmm, if you are running a fridge in hot conditions whilst not driving, plug it straight into the hook up and cut out the middle man (the charger) ! That's what I do, it saves charging batteries 👍
50 Shades of Pennine Grey
Post #932148 2nd Dec 2021 10:08am
Mo Murphy
lilyharry wrote:
Thank you for sharing information with us. I know you are very concerned about us, so we appreciate all you have done here.
weber bbq
Spam alert ?
Post #932149 2nd Dec 2021 10:10am
Undoubtedly, confirmed if you look at the other posts that this person has made. Reported to our most excellent Admin.
Anyone considering fitting a mains hook-up to their Defender might want to be aware that BS 7671:2018, the 18th edition of the Wiring Regs, introduced considerable requirements and restrictions on vehicle/mains electrical hookups. If compliance concerns you it might be worthwhile and sensible to consult a sparky with the relevant knowledge for advice.
Post #932151 2nd Dec 2021 10:26am
