Home > Puma (Tdci) > Engine temp not really rising |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
That's not normal. On a seriously cold day like -3 and lower, in stop start traffic it will cool down but apart from that the heater is nuclear unlike older vehicles. You need to get it looked at. 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
4th Mar 2018 7:21pm |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
I do an 8 mile 15 minute drive most mornings (all 30mph roads) and in all but the coldest of days I'm reaching for the heater control to turn it down by the time the journey is nearly over because it's getting too hot.
From memory on this drive I don't think my needle reaches half way either, but it does rise a little after about mile or so and this is my notification to turn the heater on. Note that I usually keep the air in recirculate mode until the needle is on at least a quarter as I find this helps keep the heat in the cab, rather than filtering ice cold air in. I'd say you have a problem if it's not warm in 40 mins. My old TD5 would need a blast up the motorway to get any heat out Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
4th Mar 2018 7:41pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
I had a very similiar problem with my Tdci 2.2 ( didn’t have in on the 2.4 or TD5 I have previously owned ) had the thermostat changed and it certainly improved but having driven my wife’s 2.4 this weekend and my 2.2 the 2.4 engine warms up much quicker than the 2.2
Welcome to the joys of owning a Defender, your wife will soon learn to love it unless you keep spending money on it like the rest of us 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
4th Mar 2018 7:49pm |
Beeder Member Since: 19 Nov 2017 Location: Nuneaton Posts: 17 |
Appreciate the reply’s I’ll get it booked in - I’ve created a ‘secret’ eBay account already as I’ve been busted several times , (double din and seat upgrades )
4th Mar 2018 8:21pm |
If that fails and the 2.2 is just slow to warm (mines a noisy 2.4) then you could install a wading/snow blanket to the front grille. Google them and you'll see what I mean.
That and keeping the air on re-circulate should help Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
4th Mar 2018 8:52pm |
sounds like the thermostat has failed open.
You can remove them and test them, but they're so cheap I've always just fitted a new one. I mean if you test it and it doesn't work you'll need to get one anyway. |
4th Mar 2018 11:44pm |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
I used to use a home made snow blanket, part of a cardboard box shoved in front of the radiator. It worked a treat and at the right price! However as said I firstly would put a new thermostat in, they can fail after a very few years or last a very long time!👍 strangely started my Puma cold this morning and the Ultraguage was already showing 30C, I will have too check that one out ASAP!
5th Mar 2018 6:59am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8051 |
try running it with the heater off until the temp gauge starts to move as suggested ^^^^
if your at low revs and never over 30mph with fans on full i doubt it will ever warm up unless the vehicle is being used hard offoad and/or towing. does the temp gauge move at all? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
5th Mar 2018 1:47pm |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
mine takes a while to warm up but yours is taking a lot longer a thermostat change would not hurt . i must say iv been told many times a engine that warms up to fast has more problems than cold .
5th Mar 2018 2:05pm |
SingletrackFred Member Since: 23 Mar 2015 Location: Reading Posts: 66 |
I had the same issue. It was a broken thermostat, replaced and working fine now.
10th Mar 2018 4:26pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Mine heated up quickly, but then cooled down just as quick. Slow green laning at a crawl in the Dales and the heater was barely keeping me warm.
10th Mar 2018 6:23pm |
