Home > Technical > windows of the diffrent year defenders |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 521 |
blimey - have you tried anger management
27th Feb 2018 9:33am |
As I said perhaps learn a few manners.
27th Feb 2018 9:47am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
The answer is no they are not the same. Just the thickness as mentioned before. However you can make it fit Land Rover style. I have 2003 glass in 1984 doors. The only things you have to change are all the doors internalls. As the lifting system is different you also need to use the newer inside door plate or modify the old one. And as the newer glass is thicker you need the glass guiding thing also from the new glass.
But then if you chnage to the newer door inside panel door inside door opener doesn't fit so you might have to modify that. etc. But you can do it. Click image to enlarge Like I said 1984 doors with 2003 glass. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
27th Feb 2018 9:54am |
