![]() | Home > Puma (Tdci) > TDCI 2.4 Alternator and Dual Battery Setup |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
VSR charges the second battery on my puma2.4 just fine!
Arsath Member Since: 20 May 2015 Location: Sri Lanka Posts: 133 ![]() ![]() ![]() |
Thank you!
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
Smart alternators are essentially those that have their output voltage controlled externally via the Engine Control Unit (ECU) rather than by an internal voltage regulator as found on traditional alternators.
Defenders have always been fitted with traditional alternators, which maintain their voltage between 13.8-14.4V depending on battery condition, load etc. and vary their output to match the number of amps being drawn. You'll be fine with a standard setup matched to your needs. I bet the new Defender will have a smart alternator though to comply with emissions which means we'd all need to buy expensive battery to battery chargers for dual battery set ups and then you can't use gel batteries either as they get damaged by these alternators apparently! Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 ![]() ![]() ![]() |
Does the 2.2 have a smart alternator?
Not that I've ever seen!
I know the latest Discovery and RR have them. Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
Thanks!
millepet Member Since: 01 Apr 2013 Location: Wijnendale Posts: 33 ![]() ![]() ![]() |
&ab_channel=Trailerfitter%27sToolboxVideos
tdci's have a smart alternator: watch the video |
