Home > Puma (Tdci) > My new defender- but the speakers not working?
Jimbob
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
Hi all, I'm new to the site! I picked up my 2009 tdci 90 today and I'm chuffed to bits with it, only problem I have is the drivers side front speakers aren't working? I've adjusted the balance all the way over and the sound only comes from the rear. It's under warranty so I can just take it back at the weekend, but I was just wondering if it's only a common loose wire or something that I can look for?
thanks!
James 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader
2015 Defender XS Hard Top (awaiting delivery 😄)
Post #64096 17th Mar 2011 5:08pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Re: My new defender- but the speakers not working?
Jimbob wrote:
... I was just wondering if it's only a common loose wire or something that I can look for?
it could be ... just remove the speaker and check ... if you can't see anything, take it to the dealer.
It used to happen on my Td5 ... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #64114 17th Mar 2011 6:42pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
The standard speakers aren't the best, so it's likely that one has blown. I had the same thing with my passenger speaker. When mine went, I took both speakers out and swapped them over just to make sure that it was a dud speaker, which it was.
It's unlikely to be a stocked part at the dealers (it wasn't with mine), so be prepared to take it in for them to diagnose a broken speaker, and then go back once they've ordered it to have it fitted. Alternatively, for around twenty/thirty pounds you can by a much nicer set of speakers off eBay… (there are a few threads on here of recommendations if you go down that road). Welcome to the site Thumbs Up Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #64133 17th Mar 2011 8:02pm
Jimbob
Thanks for the replies, the thing that baffles me though is it's not just one speaker, if it was just one I could under stand but the whole front corners not working. The top tweeter and the bottom larger speaker are both dead silent? :S have to go to LR I reckon! 2009 Defender County Hard Top (gone 😞)
Post #64152 17th Mar 2011 9:57pm
AndrewS
The are wired in parallel so if one goes the other wont work. or is it series no its parallel I think or perhaps it is series yes its series. 130's have feeling's as well you know Smile
Post #64156 17th Mar 2011 10:11pm
TC
Just swap them around, this will tell you very quickly if it's the speakers.
Post #64159 17th Mar 2011 10:20pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
If both speakers at the front are not working are they plugged in????
If the speakers are plugged in, are they plugged in at the radio????
If you are able to alter front/rear balance and L/R as well then each speaker should be individually wired to radio, BUT the plugs might be double ie: both rear speakers in 1 double plug, likewise front speakers. The front speaker plug might not be plugged into rear of radio.
Post #64162 17th Mar 2011 10:23pm
mse
I have a pair of defender speakers Mike
Post #64189 18th Mar 2011 7:34am
