Home > Puma (Tdci) > My new defender- but the speakers not working? |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
it could be ... just remove the speaker and check ... if you can't see anything, take it to the dealer. It used to happen on my Td5 ... Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
17th Mar 2011 6:42pm |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
The standard speakers aren't the best, so it's likely that one has blown. I had the same thing with my passenger speaker. When mine went, I took both speakers out and swapped them over just to make sure that it was a dud speaker, which it was.
It's unlikely to be a stocked part at the dealers (it wasn't with mine), so be prepared to take it in for them to diagnose a broken speaker, and then go back once they've ordered it to have it fitted. Alternatively, for around twenty/thirty pounds you can by a much nicer set of speakers off eBay… (there are a few threads on here of recommendations if you go down that road). Welcome to the site Peter 2008 SWB Truck Cab 1952 80" Soft top |
17th Mar 2011 8:02pm |
Jimbob Member Since: 17 Mar 2011 Location: Gower Posts: 68 |
Thanks for the replies, the thing that baffles me though is it's not just one speaker, if it was just one I could under stand but the whole front corners not working. The top tweeter and the bottom larger speaker are both dead silent? :S have to go to LR I reckon! 2009 Defender County Hard Top (gone 😞) 1990 200tdi defender off roader 2015 Defender XS Hard Top (awaiting delivery 😄) |
17th Mar 2011 9:57pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
The are wired in parallel so if one goes the other wont work. or is it series no its parallel I think or perhaps it is series yes its series. 130's have feeling's as well you know
17th Mar 2011 10:11pm |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
Just swap them around, this will tell you very quickly if it's the speakers.
17th Mar 2011 10:20pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
If both speakers at the front are not working are they plugged in????
If the speakers are plugged in, are they plugged in at the radio???? If you are able to alter front/rear balance and L/R as well then each speaker should be individually wired to radio, BUT the plugs might be double ie: both rear speakers in 1 double plug, likewise front speakers. The front speaker plug might not be plugged into rear of radio. |
17th Mar 2011 10:23pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
I have a pair of defender speakers Mike
18th Mar 2011 7:34am |
