![]() | Home > For Sale & Wanted > [For Sale] window blocks |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2057 ![]() ![]() |
Look great!
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 ![]() ![]() ![]() |
I'd have a pair but my 10yo blocks are still perfect. My Td5 had 3 sets in half that time.
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Yes, there isn't much logic to it. I had a 2000 TD5 that was fine, but I've seen them bubble up on 2015/2016 vehicles. Perhaps it depends on whether the paint shop is in a hurry that day!
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 495 ![]() ![]() ![]() |
Mmmm, wonder if I could persuade Land Rover to fit these instead of their own!
2016 and 2015 defenders both going in for warranty work imminently, including the inevitable corroded window blocks ![]() 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 262 ![]() ![]() |
Payment sent! 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
Do these need painting or is the ha enough protection for them? Also, my internal bolt plates are rusty as hell, do you have replacement options there?
Hi Miker,
They don’t need to be painted. If you were to leave them unpainted I would suggest a coating of wax to prevent them fading. I don’t have replacement bolts available but will look to source some. Thanks Huttopia |
Hi Adseybear,
Payment received with thanks. The blocks will be shipped tomorrow (Friday) morning. Many thanks Huttopia |
Hi Doublea,
It is definitely worth asking the question! The paint finish on these will be much better and longer lasting than the standard LR cast blocks. Huttopia |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
The paint quality is ok on the Lr blocks usually!....The problem is that the underside is not painted and where the unpainted edge meets the exterior paint if the paper seal allows moisture to build up and the small Ali block becomes a sacrificial anode to the bulkheads cathode....... If there is a good barrier between the block and the bulkhead you will slow down or stop the corrosion...pity LL did not paint the underside..cheapskates'!!
Some nice rubber gaskets will help:
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1882 ![]() ![]() |
PM sent, ta. Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
That would do it..i would add some grease or acf grease as well....can you buy those or are you nifti with the scissors' |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
https://www.powerfuluk.com/vehicles/land-r...t-4pc.html |
