Home > Off Topic > Caravan to classic tower
jonesfrm
i have an just got my hands on a Elddis caravan thats rotten out. It is a Single axle and will be used to transport a 1978 mini. I intend, and have begun, stripping it down to the chassis. Just wondering if anyone else had done this kind of thing before?
Any advice is warmly welcomed! Thumbs Up
Post #686022 12th Feb 2018 12:20pm
fisha
Will it carry a mini weight wise ? -------------------------------
I miss my V8's....
Post #686428 13th Feb 2018 8:19pm
grafty99
Yes be careful with weight.
Aside from the fact that all trailers built after 2012 need testing (IVA type test)
Check the MAM of the caravan plate and also max draw bar and axle ratings.
Most single axle caravans top out at the 1200kg mark. By the time you've built a bed, carry ramps and then add the vehicle you would be very close to that I would have thought Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #686456 13th Feb 2018 9:31pm
PumaPhil
Wales 2015 Defender 90 Puma 2.2 HT Aintree Green
I stripped a caravan with the intention of using it to transport a 4 metre SIB boat. There isn't actually a lot of chassis to them - just a simple rectangle - the rest is built from timber. However what was there was just in the wrong place, for my use. I scrapped it and bought a proper boat trailer. Have you compared build costs against a proper car transporter?
Post #686579 14th Feb 2018 1:45pm
Procta
I am sure a mini weighs about 750kg if I am right,
are you keeping the body of the caravan? or just using the chassis? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #686758 15th Feb 2018 1:32pm
