![]() | Home > Tdi > Viscous fan removal - any hints or tips? |
Sancho Member Since: 28 Mar 2017 Location: Winchester Posts: 24 ![]() ![]() ![]() |
I had one fitted to my 2006 110 TD5 roughly 9-10 years ago and I "thought" they were good... however the problem is the fitting via zip ties through the radiator, this causes the electric fan to rub on the radiator over time and create a hole. This was after 3-4 of years and small enough to stop with Radweld but will eventually fail... ![]() Click image to enlarge ![]() Click image to enlarge They may well have changed this method of fitting by now but I wasn't impressed. I have now fitted a kit from Revotec which on first impressions seemed good, they provide a custom made shrouding to fit the fan away from the radiator. But after an order mix up and a 10% charge to swap for the correct kit for my TD5, I still ended up modifying the shrouding to prevent rubbing on the radiator ![]() Last edited by Sancho on 19th Feb 2019 12:21pm. Edited 1 time in total |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 363 ![]() ![]() ![]() |
Mmmm... Not in Africa you won't. |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
Doesn't work so well off road or towing with a strong tailwind! --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
