Home > Maintenance & Modifications > Interior Mirror.
Page 2 of 3 <123>
JeremyJ
Post #684731 7th Feb 2018 10:16am
AJC
Chopperone wrote:
Ian Baughan
IRB developments used to advertise them.
Not an easy chap to make contact with.
I failed miserably when I tried some 16 months ago, no real website, emails unanswered, phone calls & voice mails ignored yet many sing his praises.
Spent the best part of 5k elsewhere & still spending.
Not sure l am alone.
Guy
you're definitely not alone
Post #684737 7th Feb 2018 10:55am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
I found that they existing mirror could be improved by making sure the three screws on the mounting bracket were really tight and also putting some Sugru between the mirror arm and the bracket as I clipped it back on.
The Sugru (mouldable silicon putty) takes up all the slack between the bracket and the arm. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #684761 7th Feb 2018 1:20pm
zsd-puma
I don't find mine vibrates much really, but then being a USW with a cage in the back I can't see much out of it anyway. So I reckon tightening the fittings is worth a go. The windscreen frame fittings probably work loose over time too, so wouldn't hurt to go around with a screwdriver and tighten them all up, as they'll add to the vibration if they're loose.
The SVX stabiliser arm is part number LR013823, I've not checked availability and it's not cheap. A bit of rubber block cut to fit with a cable tie around it would do it too.
Post #684763 7th Feb 2018 1:45pm
ericvv
Had never even heard of existence of that support. Surely my SVX did not have that at delivery. But my mirror does not vibrate, so I’m not missing it. Part seems available in Germany at €72.00 though.
Edit - just found out it was only installed in the SVX soft top version, not in the 90/110 SW versions.
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #684772 7th Feb 2018 3:06pm
zsd-puma
It was possibly only fitted to soft top versions, where there is likely to be more vibration through lack of windscreen support from a roof.
Post #684773 7th Feb 2018 3:16pm
I've never seen one either. When I removed the internal mirror from my '07 DC is not only didn't have one of those but also was so firmly in the clip in the roof that I had the greatest difficulty getting it off.
I don't really understand why that support is necessary, unless I had an unusually stiff one.
Britpart lists it as well, for £50+ Shocked
Edit - the soft top theory sounds extremely plausible.
Post #684774 7th Feb 2018 3:17pm
ericvv
Post #684775 7th Feb 2018 3:18pm
donmacn
Clayton, your car must be a 'wannabe' soft top! Razz Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #684778 7th Feb 2018 3:50pm
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
I would try a new mirror as sometimes the knuckle is worn, that worked for me. Alternatively might be able to wrap some ptfe tape around the balljoint to give it a tighter fit?
Post #684779 7th Feb 2018 3:59pm
L110CDL
Many thanks to all of you, JerermyJ you are spot on, many thanks and only at £52 Shocked Laughing Clayton.
Keeper.
Post #684849 7th Feb 2018 9:36pm
L110CDL
jrule, mine has always vibrated and when i hold the arm it stops, so thats why i put a cork there, but with everyone saying that there mirror does not vibrate, i just thought that they all did Laughing
So i will have to look into this in depth a bit more Very Happy Clayton.
Keeper.
Post #684853 7th Feb 2018 9:39pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Clayton, you could always do your hair/make up before leaving home like I do Rolling with laughter
I suppose this highlights the difference between truck cabs and station wagons. With tinted windows and kids seats I can barely see the back door. And this is reduced further by the spare mounted on the door. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #684888 7th Feb 2018 10:43pm
L110CDL
^^^ Rolling with laughter
It sure does show the differences between them all Very Happy does this mean that it can come under the category of " LR Tolerances " Laughing Clayton.
Keeper.
Post #684899 7th Feb 2018 11:00pm
zsd-puma
It might also just be a resonance thing. Some vehicles hit the right resonant frequency to make it vibrate, others don't. And that could just be down to slight differences in tolerances in the drive train.
It's not just a Land Rover thing. I used to work in a large fleet. Out of more than 30 identical Sprinters at our depot you found large differences between them in terms of the way they drove, even from new. Some were smoother than others, some were quicker away from the lights. Some had nice light gear changes, some were quite heavy etc. Same with the lorries, Some pulled better on hills than others, some were smoother than others.
Post #684919 8th Feb 2018 1:17am
Page 2 of 3 <123>
