Home > Puma (Tdci) > Inlet manifold grey slime
Moash
2007 Defender 90 Puma 2.4 HT Stornoway Grey
Hi,
Just changed the glow plugs in my 2007 2.4 tdci and noticed a lot of grey sludge / slime in the inlet manifold.
Any ideas if this is normal or a problem? I’m a bit concerned its water and oil mixing.
Many thanks,
Scott
Post #683403 1st Feb 2018 1:17pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Not seen that on a TDCI before,
Defenetly water/condensation and oil?
Do you use it regularly or just short trips,
Is it parked up for long periods?
The only vehicle I know suffers badly with this, is anything with a Vauxhall engine,
And it’s caused by condensation. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #683409 1st Feb 2018 1:32pm
Moash
Its used daily but only for vey short trips to and from work. (only a couple of miles to work)
Coincidently the turbo actuator packed in during the summer and I was told short journeys would have probably helped cause this.
I've been trying to do longer journeys at the weekend to allow the engine to reach normal operating temperature but the damage has maybe already been done.
Any ideas where the oil would come from? coming back round from the EGR?
Thanks,
Scott
Post #683429 1st Feb 2018 2:45pm
Most probably from the engine breather (the reason why many of us fit Provent devices or catch cans).
Post #683431 1st Feb 2018 2:54pm
Moash
Thanks for the replies.
I've had a look through the threads about the Provent 200 but some of the photos are now unavailable.
Don't suppose anyone has some pictures of a 2.4 tdci fitted with one?
Thanks,
Scott
Post #683467 1st Feb 2018 5:54pm
