![]() | Home > Series Land Rovers > New wiper motor for Series 2a. |
EWG Member Since: 20 Sep 2015 Location: Betws y Coed, North Wales Posts: 102 ![]() ![]() ![]() |
Can I have some advice please.
Two years ago I changed the original bulkhead on my 1962 Series 2a to a refurbished on from a later 1969 model which has the rack type windscreen wipers. The wiper motor situated on the left (nearside) of the bulkhead has now burned out so it's replacement time. Is the Series 3/Defender type windscreen wiper motor a direct replacement for the later Series 2a one? I've been reading on the 'net that there are conflicting opinions as to whether it is. Has anyone any recommendations as to the best one to buy? Thank you. |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 632 ![]() ![]() ![]() |
It is a replacement. Not a direct replacement.
If the motor fitted to your bulkhead is an original one it will have a rectangular case. Series III and IIA Lightweight used a round cased motor. With the later brackets and rubber mount it can be made to fit. Connections are slight different as well. 1995 Defender 110 CSW 1971 SIIA Lightweight |
Thank you gentlemen.
