Home > Puma (Tdci) > Seat belt anchor bolts Part Numbers
ChrisCod
United Kingdom 2010 Defender 110 Puma 2.4 SW Alaska White
I was wondering if any body know what the Part Numbers for the seat belt anchor bolts, nuts and washers are on a 110 CSW, mine are preety corroded and I plan to change the seat belts and carpets when the weather improves, if it ever does that is Confused I understand that these are only be available from LR is that correct?
Post #682229 28th Jan 2018 7:31am
dorsetsmith
FS108256
M8 x 25,Bolt the only refrains may be wrong
Post #682238 28th Jan 2018 8:59am
