Seat belt anchor bolts Part Numbers
I was wondering if any body know what the Part Numbers for the seat belt anchor bolts, nuts and washers are on a 110 CSW, mine are preety corroded and I plan to change the seat belts and carpets when the weather improves, if it ever does that is I understand that these are only be available from LR is that correct?
28th Jan 2018 7:31am
dorsetsmith
FS108256
M8 x 25,Bolt the only refrains may be wrong
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
