Home > In Car Electronics > USB Playback on Alpine CDE133 Headunit
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
I'm just trying to confirm I've got the right end of the stick here (excuse the poor pun), but on the standard Alpine headunit, am I right in saying I can stick an MP3 onto a USB memory stick, plug into the USB port on the front of the unit, switch the source and it should play the file?
I tried this last week, and all I got was an error message (cant remember the exact wording). The file was a MP3 podcast about 1hr 30mins. Is this the problem?
Thanks 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #681100 23rd Jan 2018 5:15pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
The CDE-133BT is a bit horrible when it comes to - well almost anything really. It does play MP3s off the USB stick but it must be formatted FAT32 at most and is also picky about the bit rate of the MP3 file.
I keep meaning to replace it with something better because the play/pause/next/back buttons don't work when connecting my my current phone via bluetooth.
And as far as I can tell the firmware upgrade that Alpine have available on their web site doesn't work on the Land Rover version.
The manual for it is here https://www.alpine.co.uk/fileadmin/user_up...3BT_EN.pdf. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #681108 23rd Jan 2018 5:45pm
Rosco
Thanks nosi, but anything more technical than me knowing it's an MP3 is getting beyond me. Embarassed
I'll just continue downloading to my phone and stream via the Bluetooth. Your right though not the best headunit but ticks a box at the moment 2007 - Stornoway Grey 90 XS SW - Gone
Post #681162 23rd Jan 2018 9:36pm
AMBxx
When you format a USB drive on Windows (no idea about Mac), the actual format depends upon the USB drive's capacity. This won't necessarily be supported by the radio. Especially as large drives end up formatted as xFAT.
I use a little utility called GuiFormat to allow me to specify FAT32. If you can't find it, PM me and I'll send you a download link to my copy (it's a freebie thing).
Post #681250 24th Jan 2018 8:56am
I'm not a fan of Alpine for all these reasons. TheThunderRolls🇬🇧🇺🇸
Post #681334 24th Jan 2018 2:50pm
Rosco
Thanks AMB Thumbs Up
I think I've fixed the issue now Embarassed Heeding your advice I've grabbed the memory stick this morning and realised that the MP3's I've downloaded are all corrupt.
So I've downloaded them again, put them on the stick as they came and its a simple plug and play. 2007 - Stornoway Grey 90 XS SW - Gone
Post #681341 24th Jan 2018 3:05pm
Blondie
There is a firmware update available from Alpine. It helped with BT connectivity not tried with USB though.
The firmware has to be installed by Alpine on the defender unit, you have to remove the headunit post to Alpine, they will carryout the update and post back to you. From memory it took about a week. For me it made the unit far more useful until I can fit a double din unit.
Hope this helps.
Post #681356 24th Jan 2018 4:26pm
