Home > Wheels & Tyres > AT tyre longevity
Mwd
AT tyre longevity
Can anyone give me an idea of how many miles I would be likely to get out of a set of BFG All Terrain TA KO2 on a standard 110 2.2 Tdci? I drive >95% on the road and my original Continental Crosscontact AT tyres are getting a bit thin after 62,000 miles. The only reason for looking at the BFG is that the snowflake label suggests they should be better in snow & ice than the Continentals, which I have been really happy with so far (but not needed to test in proper freezing conditions). Thanks
Post #676113 5th Jan 2018 4:25pm
camelman
You should get a similar sort of mileage out of the KO2s.
The KO2s are good in the snow / ice, I swapped to them from KM2s mainly for that reason and the noise levels.
Post #676117 5th Jan 2018 4:36pm
grafty99
I wore my BFGs down to about 3mm of tread in 65,000 miles so about that I'd imagine Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #676139 5th Jan 2018 5:41pm
Retroanaconda
They’re very good. My last set of BFG AT KOs did 72,000 in two years. The lowest was about 2.5mm at that point so they were effectively worn out though still legal.
Replaced with a set of KO2s, so one hopes they will also perform similarly well (though I suspect not).
Post #676198 5th Jan 2018 8:30pm
leeds
BFG A/T fitted to our white 90 and with 36,000 miles they do not seem particularly worn. So would expect at least 60,000 out of them. The only reason I would not xpect 60,000+ miles is if the annual mileage is not enough and th3y age befor3 th3y wear out.
Brendan
Post #676205 5th Jan 2018 8:52pm
Lou Sparts
My BFG A/T KOs have done about 80,000 miles so far over about 6 years still have approx 5mm of tread left but looking a bit perished now due to their age so will change them this year will definitely replace with A/T KO 2s. 2005 Td5 90 XS
Steve
Post #676462 6th Jan 2018 8:42pm
Sulisuli
I had 80000 out of mine in just under 6 years, sold the SVX then but still had tread on them but as Brendan says they would be due for replacement due to age, very pleased with them as a tyre have the AT KO 2s on the replacement for the SVX. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #676470 6th Jan 2018 9:01pm
leeds
To find the age of the tyres look for the DOT code. Explanation here
There are differing advice on what age tyres should be replaced. Personally I look at replacing them at 7/8 years old even if plenty of tread left, some advise 10 years.
Look for cracking between tread blocks and cracking around wheel rim.
Cause of tyres deteriorating include ageing, stress from being parked in one position for long periods, UV exposure, thermal ageing, exposure to salt.
Brendan
Post #676480 6th Jan 2018 9:43pm
