Home > V8 > LT85 transfer box oil
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
There seems to be some conflicting information regarding which oil to use in the LT85 transfer box. I have read that both 20:50 engine oil and EP90 is correct.
Can someone supply the definitive answer please?
Post #675606 4th Jan 2018 12:19am
Transfer boxes are all EP90
There was one main gearbox that used engine spec oil as opposed to EP, but I forget which it was now. LT95 4 speed?
Post #675626 4th Jan 2018 7:37am
defender9
Yes my mate has a 110 Stage One with a LT95 transfer box which uses engine oil. Possibly that's where the confusion emanates from.
Post #675665 4th Jan 2018 10:57am
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
hang on a moment, do you mean an LT85 gearbox or the LT230 that fits on to it? V8 90...WIP
Post #675851 4th Jan 2018 7:31pm
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
LT85 uses 20w50 as well. JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #675856 4th Jan 2018 7:43pm
defender9
Paul, the transfer box which goes with the LT85 which as you correctly mention is the LT230.
Post #675884 4th Jan 2018 8:53pm
The LT95 is the original four speed box used in the Range Rover, Stage 1, 101 and early V8 90's and 110's. It had an integral transfer case and used 20/50 engine oil.
The LT85 is a five speed box produced by Santana in Spain and replaced the LT95 in V8 vehicles as it was stronger than the original five speed LT77. It's used in conjunction with the LT230 transfer box. The LT85 also uses 20/50 engine oil. Darren
Post #675889 4th Jan 2018 9:03pm
Paulv8
OK, well as others have said that's a standard LT230 and uses gear oil EP90 V8 90...WIP
Post #675892 4th Jan 2018 9:09pm
defender9
Thanks Paul, it’s what I thought but glad of the confirmation.
Post #675911 4th Jan 2018 9:49pm
