Home > Maintenance & Modifications > Daylight running lights
Page 1 of 4 1234>
TZ7XGP
United Kingdom 2009 Defender 90 Puma 2.4 SW Santorini Black
Has anyone fitted daylight running lights to a Defender. Question
Post #63096 10th Mar 2011 12:31pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
yes, fitted a DRL module to the high beam.
Post #63106 10th Mar 2011 1:01pm
Merlin
I have DLRs using the front side light. I fitted series rear stop/tail holders with a clear lens and LED lamps. This give 21W on both sides. I'll send you the diagram if you PM me with your e-mail address.
Merlin
Post #63186 10th Mar 2011 7:27pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Ca anyone explain how to do this?
I fiitted the SVX type headlamps to my 110, and used the sidelights in these. This frees the original sidelights to be used as DRL, but unure as to how to wire these up for DRL. IS there an SVX type plug snd play wiring loom addition for DRLs?
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #63525 13th Mar 2011 12:12pm
nicks
There is no plug and play option. The best way is to buy a module that is simply clips on to exisitng wiring. This way it will switch on and off with ignition and also off when the lights are switched on.
Post #63798 15th Mar 2011 12:50pm
AndrewS
Cant you simply turn your lights on in the day if you want DRL?
Or am I not getting the point? Embarassed 130's have feeling's as well you know Smile
Post #63801 15th Mar 2011 12:58pm
BigMike
If you're not then neither am I. I think maybe its just for ease of not having to spent a nano second flicking a switch?
Also, if we're talking about headlights rather than side lights, there is nothing more annoying than being followed on green lane by a truck with its lights on unless they are absolutely needed ie its dark. the constant lifting of the front end means you have to dip your rear view mirror
Post #63802 15th Mar 2011 1:20pm
mse
I think I got told off last time I suggested similar Mike
Post #63819 15th Mar 2011 5:28pm
nicks
Its because DRL's either use main beam or a far brighter lamp than normal.
Post #63916 16th Mar 2011 1:23pm
Surely it would be illegal to use main beams?
DRLs used to be limited to 21 watts.
Stupid things anyway, if you can't see an oncoming car without them you shouldn't be on the road! Good idea on bikes, not cars. Very Happy
Post #63918 16th Mar 2011 1:26pm
nicks
There are alot of people who are on the road though, that shouldn't !
They use the main beam but on a reduced voltage. Gives a different beam pattern
Post #63919 16th Mar 2011 1:36pm
mse
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Bow down Bow down Bow down Bow down Bow down Bow down Bow down Thumbs Up Bow down Thumbs Up Milestone Mike
Post #63925 16th Mar 2011 2:04pm
I couldn't agree more! Thumbs Up
It can't be a different beam pattern then, just dimmer. I still don't see how it can be legal, given that it is illegal to have a light which may dazzle oncoming drivers, unless it is so dim that the aggregate effective output is less than or equal to 21 Watts.
Post #63930 16th Mar 2011 2:51pm
Grockle
I leave the interior light on (full power though) for safety Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #63931 16th Mar 2011 3:08pm
nicks
Ok, maybe not a different beam pattern, but a more striking light.
All the cars that have them now are either very bright led's (Audi) or they are using the mainbeam spots - (Fiat 500, vauxhalls)
Post #63936 16th Mar 2011 3:41pm
Page 1 of 4 1234>
