Home > In Car Electronics > Speaker upgrade in TD5 |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Id be worried about them getting rather wet!
31st Dec 2017 12:07am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1428 |
They would do the job, although you'd probably find cheaper on the bay, halfrauds probably stock them too. I'd doubt you'd get angled like the originals. All my installs have been flush mount. Personal preference |
31st Dec 2017 9:41am |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Cheers , I see mudstuff do some rear corner speaker panels that look good too.. I'll make a shopping list next month and keep you all updated. They also do a neat sub that fits under the cubby box in the middle .
http://www.mudstuff.co.uk/mud-sub-locker-953.html http://www.mudstuff.co.uk/mud-rear-speaker-panel.html |
31st Dec 2017 1:21pm |
Looking at these speakers from JL audio as they give me flexibility on how I install them. Any ideas if there is enough room to hide the crossovers behind the speakers some where?
https://www.caraudiocentre.co.uk/product_m...-33118.htm |
31st Dec 2017 6:13pm |
There is room the focal power crossovers are massive and I got them to fit. You'll be fine
31st Dec 2017 8:32pm |
Edging towards this flush mount method, I've made a few card template of speakers size and 116mm for the hole to get an idea. Did you cut the leather type dash material or stitch drill it along with the metal? Last edited by Djcla on 1st Jan 2018 10:54pm. Edited 1 time in total |
1st Jan 2018 9:43pm |
You don't push them up towards the screen and trim the excess. It will allow you more depth. Pm me your number if you'd like to talk about it more
1st Jan 2018 9:59pm |
I'll try and remember to take a photo tomorrow for you it's worth it
1st Jan 2018 10:19pm |
Photo be good thanks, I'm not quite ready yet to do the work just trying to plan the job and get my head around the work needed. Photo be great thanks as not sure what you mean by push up towards screen above.
1st Jan 2018 10:58pm |
Click image to enlarge Might make more sense now you can see the old footprint of the standard speaker and 2 fixing holes. But the hole has been cut for the new 5.25" speaker. In this case the orientation is across to the left, however it works better moving then up towards the windscreen, allowing maximum clearance from the bulkhead |
2nd Jan 2018 10:37am |
Click image to enlarge And fitted |
2nd Jan 2018 10:47am |
Click image to enlarge And tweeters flush mount |
2nd Jan 2018 10:51am |
thanks, what ill do is stick my templates on the dash and see how things look and post up some pics. As you say measure lots and cut once.
2nd Jan 2018 11:25am |
its like a rabbit hole this as the speakers i found are too over powered and need an amp LOL.. Anyway ill decide on that later but a question for now is can you get adapters for the connectors on the LR speaker cables to save chopping them?
3rd Jan 2018 4:48pm |
