![]() | Home > Technical > The definitive snagging list of warranty fixes |
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 ![]() ![]() ![]() |
Sorry to hear of your problems Softail.
I'm new to the site and have been the relatively happy owner of a puma 110 for just over a month (2200 miles) with only a couple of issues: Symptoms: clatter from underneath vehicle, sounding like the front and obvious when on overrun/downhill on poor surfaces - goes away when brakes lightly applied Cause: Suspected brake pads loose in the callipers or missing/weak anti-rattle springs Known fix: According to the dealer there is a service bulletin for this - problem resolved Comments:problem ALMOST resolved, but still more rattling than I've ever had with TD5 110xs and range rover classics - will be crawling underneath to take a look Symptoms: Water leak into driver and passenger footwell (exactly like yours!). very bad on old TD5, slight on new Puma 110 Cause: In the case of my old TD5, bulkhead/screen joiners appeared poorly sealed, water could be seen on the nuts and ends of bolts on the inside of the bulkhead, tracking down and dripping off the bulkhead onto the floor. Known fix: TD5 - Fixed by dealer, not sure what action they took Comments:Will get this looked at next time the Puma goes in for anything else, as not too bad in spite of very heavy recent rain. As you say, more of an issue when left standing than when driven Symptoms: Occasional metallic rubbing/grating at low speeds after a run (ie more than 5 miles) - very noticeble at car park speeds. Sounds like once a revolution of the wheels, but hard to say. Very intermittent and not yet addressed, but will keep you posted The issues with clunks from the transmission on gear change (especially under load, 1st to 2nd) also apply to my car, although the demonstrator I drove did this, as did my TD5 with 6,000 miles on the clock - I'd assumed it was par for the course until I happened across this site! 1953 80 1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
shorty Member Since: 31 Oct 2008 Location: Hillcrest, Kwa Zulu Natal Posts: 160 ![]() ![]() ![]() |
I experienced the exact same clattering noise from under the vehicle. I suspected it was the hand brake drum. I got my dealership to replace the unit and ive never heard the clatter ever again. I hope this helps. If your dealership wont replace it you can retrofit stronger springs yourself but be careful not to leave any signs of D.I.Y for warranty purposes. Land Rover's don't leak oil, they simply mark their territory!
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
gtveloce65,
Any comment from your dealer/Land Rover about the transmission clunks and 1st to 2nd gearshift. I have what sounds like the same, and Land Rover say "it's characteristic of the marque sir". As a vehicle test Engineer I can't accept that, but not sure how to get anything more done about it. Bosun |
Shorty - thanks, I'll raise that next visit and let you know - as the 'faults' have been slight and haven't altered since day 1, I'm saving this 'til the next clear-cut reason for a visit - probably the slight bulkhead leak which I had during the first few days of ownership, and which has now reappeared with the recent downpours.
Bosun - same goes for the clunkiness - it's not bad, but i don't really think it should be there. However, I've owned a couple of series LRs and 2 RR classics and all have had similar symptoms - it's as if the 'acceptable' backlash in all the components in the drive train becomes less acceptable once it's all added together, especially in the lower gears. The rear propshaft in my old TD5 was replaced (excess play in the slliding splines) and various 'loose' ![]() 1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
evert Member Since: 23 Oct 2008 Location: antwerp Posts: 4 ![]() ![]() ![]() |
gtveloce65,
My Puma 2007 is now 7 months, and has 26000 km on it, I mostly drive on the road and had zero problems till now. I've had the same noise with my handbrake in the beginning, dealer told me that in the factory they fix it too strong, after loosening the handbrake twice they repleced the drum, and I never heard the sound again. What the water leaks are all about, here's a link from LR, where you'll find some info, me I've fixed two drainpipes, wich really helps, I'll send you some pics tomorrow. Cheers, Evert http://www.lrch.nl/forum/simpleforum_files...manual.pdf |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5070 ![]() ![]() ![]() |
Yes well thats the dealer Mike |
