Home > Td5 > Third Brake light |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6113 |
I just used the stuff for sticking on rear view mirrors.
my local autofactor place does it. costs about £3, you get a little tube, and some gauze stuff you cut to size. Seems to stick OK. mine fell off a couple of times (it doesn't stick anything like the factory parts, god knows what they use) in the end, i used some black panel bonding sealer.... it hasn't moved since! |
8th Mar 2011 9:37pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2653 |
Thanks
I think that your suggestion will be the best I could not work out what the factory uses either Cheers Mark |
8th Mar 2011 10:02pm |
