Home > Technical > Defender 300Tdi 1998 Immobiliser removal
fforrester
United Kingdom 1998 Defender 110 300 Tdi SW Rioja Red
Defender 300 Tdi 1998
My apologies if this is an exhausted topic - I have searched everywhere and arrived at similar but not identical problems with other owners. I want the immobiliser removed forever.
Symptoms: engine cut-out at idle. No crank when trying to re-start. Sit for a few hours and re-start fine. I've ruled out starter motor, fuel pump etc. It's the immobiliser - that's the thesis I'm going with and I want it out.
First thing: locate the immobiliser- I think the black box screwed to the forward panel of the battery compartment is my immobiliser headquarters. There will be a relationship with the green box which sits screwed to the fire wall behind the dash but for now, I've blasted open the black metal box.
There was no performing the operation in the vehicle so I bit the bullet, labelled and then severed all 7 wires going through the grommet and into the box.
I then broke open the black plastic box which sat inside the metal one.
I discovered that the immobiliser bypass clip I purchased for this operation is entirely different form the ten-pin plug-in sitting on the circuit board !
Have I arrived at the wrong destination? Is this an immobiliser circuitry I have before me on my desk? Or have I broken into something else?
Any help appreciated !
Post #672221 20th Dec 2017 12:58pm
dorsetsmith
wrong post
Post #672229 20th Dec 2017 1:35pm
Welcome to the forum. Unfortunately, you've chosen to start with a particularly thorny subject. Because of the problems with Defender thefts, few will be keen to help with information on how to find, disable or remove factory fitted security, particularly for a new poster that nobody knows. Darren
Post #672231 20th Dec 2017 1:39pm
dannyc85
United Kingdom 2007 Defender 90 Puma 2.4 CSW Stornoway Grey
I have a similar issue. I have a 98 300tdi with immobilizer. It is currently working fine but I want it removed before I go traveling next year. I was going to take it to a garage to get this done as at least you will have reciepts etc for the future if it comes to selling.
Post #672693 22nd Dec 2017 5:27pm
