![]() | Home > Maintenance & Modifications > Alarm - Remote Operating Range |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
Could someone please pm the instructions to me as well.
Ta |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
Andrew does this apply to a 2007 Puma too? i can't believe that the "antenna" is just that crappy little piece of wire... |
Willie Member Since: 08 Oct 2009 Location: Stockton Posts: 48 ![]() ![]() ![]() |
Could you please PM me the instructions please,
Thanks Willie Defender Virgin |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
This is the 2007 my on puma defender no earlier! Mike |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2956 ![]() ![]() |
Does this work on td5 PM please cheers chris
Porbably does work on a TD5...you could look for the alarm unit on yours and see
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2655 ![]() ![]() ![]() |
Yes - it does work on the TD5, i did mine last week
much better Mark |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Puma up to 11my ![]() ![]() |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Correct,, my 11MY is much better from the factory, than previous Puma's even with the modification ![]() Main Brian James Trailer Dealer for South West UK |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 ![]() ![]() ![]() |
Could you pm me the instructions too please? Does my head in!!! Cheers
Don't worry about pm, just seen Andrews pics cheers, I'll be doin that tomorrow!!!!
Works like a dream!!! Cheers!!! Why do they not do this from new!!! Nutters
luke11 Member Since: 10 May 2011 Location: Cambridge Posts: 32 ![]() ![]() |
This is a definate job for tonight, mine works when its about a foot away at the moment
ARMYBOB Member Since: 16 May 2009 Location: north luffenham, rutland Posts: 81 ![]() ![]() ![]() |
anyone watch top gear?
put the remote against your head, it genuinely works, i always look a tw@ in the car park! |
