Home > My Defender > My TD5 90
TJH1985
My TD5 90
Hi Guys,
Heres my pride and joy Mr. Green
Haven't done much to it in the last couple of years, excluding the obvious spannering most weekends to keep her on the road Whistle she has a few dents etc but is extremaly well looked after! *pampered*
Cheers,
Tom
Post #671061 15th Dec 2017 3:12pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Nice honest truck Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #671069 15th Dec 2017 4:15pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Hi Tom
in my opinion just how a defender should look, unmolested ready to do any job asked of it!
Nice
Tommo
Post #671073 15th Dec 2017 4:49pm
Pickles
Nice pics Tom, where were they taken?
Pickles.
Post #671125 15th Dec 2017 9:33pm
L110CDL
Nice one Tom Thumbs Up Clayton.
Keeper.
Post #671308 16th Dec 2017 9:36pm
TJH1985
Pickles.
The top one is a private estate in Scotland with Land Rover Experiance on one of their adventure days.
We actually stayed in a awesome cottage that you needed a 4x4 to get to in a valley:
The second is somewhere in Wales, I think above Fairborn.
The third one is at the base of Mt Knott in the Lake District, we left it there and ran up to the top - Stupid Idea Rolling with laughter
The 4th is on Houndkirk Moor in the Peak District a regular when walking the dogs:
My current dilemma is if it would still look ok with Rock or Tree sliders fitted!?
Post #671663 18th Dec 2017 11:00am
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Cracking 90! Looks awesome! Very Happy
And yes, yes it would still look ok with rock / tree sliders! Thumbs Up Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #672026 19th Dec 2017 3:58pm
TJH1985
I’ll have to get some ordered 👍
Post #674609 31st Dec 2017 10:31am
TJH1985
it’s done very little miles this year even with a 2,000 mile trip across Europe!
Recent work includes:
    Full gearbox rebuild
    Puma transfer box
    OE Flywheel & Clutch
    New brake servo
    New crank pulley & pulley set
    VSR Split Charge & AUX Battery
    Under center seat “tool box” with power distribution for aux batter
    Safari Equip side steps
    Super Pro poly bush set
    New door hinges
    Full puma lock set - same key all round
    Rear spear wheel carrier
    Webasto FBH - In Progress
Post #741180 19th Nov 2018 12:00am
L110CDL
Nice bit of maintenance there Thumbs Up
Recent shots Question Clayton.
Keeper.
Post #741349 19th Nov 2018 10:42pm
TJH1985
Don’t have any pretty pics but here goes:
Can’t wait until summer to get the white wheels back on 😎 IMO they look much better, but the winter salt just kills them hence the boosts!
Post #741395 20th Nov 2018 8:54am
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Nice original looking Defender, same colour as mine too Cool
Post #741410 20th Nov 2018 10:08am
OsloBlue
There is something to be said about a vanilla 90 without AC. Thumbs Up
Nice Dogs too, I'm on IG: https://www.instagram.com/osloblue42/
Post #741434 20th Nov 2018 12:20pm
L110CDL
They are all good pic's Tom Thumbs Up
Just a thought as you like the white rim look, what about getting the boosts done it white Question I don't think i have ever seen a white set, would be a first Wink Clayton.
Keeper.
Post #741636 21st Nov 2018 9:15pm
TJH1985
I like the idea of white boosts, but these are a brand new take off set that are literally 6 months old so it feels a shame to strip and paint them Embarassed
I should probably start documenting some of the work so here goes with the FBH:
Started work on the Webasto install the last few nights, I have a peugeot 807/ c8 webasto thermo top as these are bolted to the car with everything you need in one place, heater, fuel pump, water pump, exhaust etc and can be triggered by +12v £90 all in Thumbs Up
First job was to test it using the Thermo test software that as per:
https://www.disco3.co.uk/wiki/Fuel_Burning...t_Software
The other half's Range Rover FBH went down, due to a failed water pump so naturally mine was sacrificed and has since been replaced with a VW aux water pump from a 2017 T5 and I have made up a new loom for it.
Fuel Pick Up
Decided to run the fuel line directly into the tank via the standard FBH connector on the fuel pump.
Its number 1 on the diagram, I slowly cut the top off until the fuel pipe was a tight fit into the tank and then fed the fuel pipe through some larger fuel host that I could seal onto the pipe and the fuel pump to prevent any leaks etc.
Fuel Pump
I am mounting this on the drivers side chassis, using the protruding bolt from the rear shock mount. The fuel pump mound that came from the 807 just needed drilling out to 10mm and reversing so that the pump sat higher.
I have a £3 Filtron fuel filter which is probably overkill fitted and moved the old 807 output pipe from the pump to the input side of the filter as it is the perfect shape to go up and over the standard defender fuel lines.
Webasto Mounting
I have just welded the standard mounting bracket onto the wing mount.
Proposed Wiring Diagram
Controller
https://www.gsm-uk.net/shop-2
Long way to go, especially as I only really spend a hour here and there and am easily side tracked by painting things I remove Whistle
Embarassed
Post #741926 23rd Nov 2018 8:33pm
