Home > Puma (Tdci) > A squeaking sound
John051
Belgium 2010 Defender 110 Puma 2.4 XS CSW Java Black
A squeaking sound
Hello,
For a few days now everytime in take a right turn I hear a faint squeaking sound coming from the front wheels? Does anyone have an idea where this is coming from?
Gr,
John
Post #62398 5th Mar 2011 7:06pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
the front wheels ?????????????
Rolling with laughter
sorry, and good luck the search for the sqeak or rattle can be a long one.
Post #62405 5th Mar 2011 7:38pm
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Well I had a noise coming around from front wheels only last week, turned out the brakes needed to be cleaned. '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #62419 5th Mar 2011 9:38pm
MK
Sometimes when brake pads get hot their edges may produce a bit of noise. You could take them off and cut a bit. Or check if the hub is tight enough. Puma 110" SW
Post #62422 5th Mar 2011 10:05pm
110SEB
Or pull an emergency stop to wake them up?
Post #62423 5th Mar 2011 10:22pm
spudfan
Ireland
Did you run over a mouse? Could be stuck in the tyre thread. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #62456 6th Mar 2011 11:43am
LR90XS2011
My new 90xs made a worrying rubbing squeeking rubbing noise from the front passender hub. It did this from new for the first 300 miles, I was about to take it to the dealers but decided to look myself first . I found the rear of the brake disk shield had no clearance so was hitting the disk the noise was then being exaggerated by the shield resonating, it simply needed a good shove to create some clearance and is now fine. Having said that I spent the first 300 miles worried and dissapointed. Suggest you look here first may be something as simple as this, good luck
Post #66910 11th Apr 2011 5:53pm
Could be grit or piece of gravel or stone Thumbs Up
Post #66913 11th Apr 2011 6:29pm
mse
Is your stereo on? Mike
Post #66926 11th Apr 2011 7:37pm
LR90XS2011
did you get to the bottom of the noise? DEFENDER 90 TDCI XS,
Post #420572 2nd May 2015 7:19am
