![]() | Home > Puma (Tdci) > A squeaking sound |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
the front wheels ?????????????
![]() sorry, and good luck the search for the sqeak or rattle can be a long one. |
lrdxb110 Member Since: 09 Jul 2009 Location: Dubai Posts: 224 ![]() ![]() ![]() |
Well I had a noise coming around from front wheels only last week, turned out the brakes needed to be cleaned. '08 LR Defender 110
'08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2462 ![]() ![]() ![]() |
Sometimes when brake pads get hot their edges may produce a bit of noise. You could take them off and cut a bit. Or check if the hub is tight enough. Puma 110" SW
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Or pull an emergency stop to wake them up?
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4761 ![]() ![]() |
Did you run over a mouse? Could be stuck in the tyre thread. 1982 88" 2.25 diesel
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3663 ![]() ![]() ![]() |
My new 90xs made a worrying rubbing squeeking rubbing noise from the front passender hub. It did this from new for the first 300 miles, I was about to take it to the dealers but decided to look myself first . I found the rear of the brake disk shield had no clearance so was hitting the disk the noise was then being exaggerated by the shield resonating, it simply needed a good shove to create some clearance and is now fine. Having said that I spent the first 300 miles worried and dissapointed. Suggest you look here first may be something as simple as this, good luck
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20715 ![]() ![]() |
Could be grit or piece of gravel or stone
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
Is your stereo on? Mike
did you get to the bottom of the noise? DEFENDER 90 TDCI XS,
