Home > Technical > Defender TD5 Diff Lock Positions
Grannville
Evening All,
Ive been looking into my diff lock light and diff lock. It seems at switch was faulty and the lock is working through jacking up the front wheel etc.
However ive been looking online at this topic and it seems there are 3 positions for the lock, looking down onto the plate from the drivers footwell:
Plate towards the drivers door = diff lock
Plate pointing towards the front of the LR = diff unlocked.
Plate can also be pointing toward the passenger side. diff also unlocked.
Now my question is, even with the linkage adjusted spot on, there is no way to select the notch pointing towards the passenger side, it will not throw the linkage close enough to the gearbox. it can be pushed in by hand but the linkage plate will start to catch on one of the 3 bolts ontop of the transfer box.
I had always assumed the 3 positions were diff locked, diff neutral and diff open.
It has been driving around fine in the diff neutral position, the diff is definitely not locked.
Any ideas?
I'll try to post some photos, in the meantime commence head scratching lol
Post #665158 17th Nov 2017 6:56pm
There are only two states for the diff - locked or open.
There are three positions for the transfer box - high, low and neutral. Darren
Post #665159 17th Nov 2017 7:02pm
Grannville
I know there are 3 positions for the ratios, and the diff lock can either be open or closed, it is just strange that there is an 3rd position on the box itself that is inaccessible on my machine, as in when you have the lever to the left it is in the most right hand position on the box. then when you have the lever in the middle position. i.e neutral it is in the centre position on the box. then right hand side for the lever is left hand side on the box. diff open.
There is a video some where if a bloke changing it with a spanner..... 2 secs
here he is with his mate james with his nipple
Post #665161 17th Nov 2017 7:07pm
Grannville
some photos of the 'middle' position
Post #665166 17th Nov 2017 7:31pm
Only two positions, locked and unlocked, "neutral" is meaningless and the bloke in the video doesn't seem to know his arse from his elbow!
If you take it apart you'll see how simple the mechanism is and how absurd the idea of neutral on a diff is Rolling with laughter
Post #665169 17th Nov 2017 7:44pm
dorsetsmith
transfer box neutral for using PTO if fitted
Post #665173 17th Nov 2017 7:49pm
True, but this thread is about the CDL not the t-box gear selector.
Post #665174 17th Nov 2017 7:52pm
Grannville
I did have a little look down the switch hole, you can see what the lever is doing, its strange the empty slot is exactly the same feel as the locked position on the ball detent, like a solid positive click
Post #665176 17th Nov 2017 7:52pm
Grannville
Aye the transfer box neutral works fine, as I do have and use a PTO
Post #665177 17th Nov 2017 7:53pm
There are only 2 notches for the detent ball in the difflock selector shaft. I suppose it is possible you're moving the shaft further than its normal travel and feeling it pass beyond the detent.
Post #665178 17th Nov 2017 7:57pm
dorsetsmith
Post #665181 17th Nov 2017 8:03pm
Grannville
Good enough for me! haha
also, any reason there is a switch on my pto linkage? it is fed 12v and is closed when the pto is engaged. doesnt seem to light anything though, the switch was broken in closed, but now it is working again although i havent noticed any difference
Post #665186 17th Nov 2017 8:28pm
I imagine it was a warning light or possibly some kind of lock-out to prevent something from happening with the pto engaged. Hard to say without knowing what the pto was originally used for.
Post #665228 17th Nov 2017 11:33pm
Grannville
Used for my winch and tool take offs, doesn't seem to make any odds, I'll add it to the 'f knows' pile
Post #665406 18th Nov 2017 9:22pm
zsd-puma
You'd have to follow the wire from the switch to see where it goes. I think on some vans with a PTO when you engage the PTO, the idle speed increases, could have been something do with that.
Post #665425 18th Nov 2017 11:24pm
