Home > Technical > 2004 Defender ABS Sensor
bankz5152
My front right ABS sensor keeps tripping out, according to the Nanocom its "electrical failure" and "intermittent XXX times"
I assume I need a new one, though not 100% sure which one!
This the right one?
https://www.ebay.co.uk/itm/Genuine-Land-Ro...Swh3NZgaoj
Or this one?
[img]https://www.ebay.co.uk/itm/LANDROVER-DEFENDER-ABS-SENSOR-FRONT-SSW500050-GENUINE-LANDROVER-PART-DEF-TD5/262501773788?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649[/img]
Two different part numbers! Two different prices but the same make...
Any help?
Post #664488 15th Nov 2017 11:38am
dorsetsmith
Wabco Front ABS Sensor Kit STC1749 Defender 83-06 - ABS models from (VIN) XA159807 to 6A999999 -
SSW500050 - ABS SENSOR KIT FRONT DEFENDER 5A>
Post #664495 15th Nov 2017 12:30pm
bankz5152
So Disco/Def arnt interchangable?
Post #664496 15th Nov 2017 12:35pm
dorsetsmith
up date also that price is good Gen LR £265 + VAT and P&P
Post #664498 15th Nov 2017 12:39pm
dorsetsmith
interchangeable up to build date
Post #664499 15th Nov 2017 12:42pm
bankz5152
Ahhh excellent! Thank you Very Happy
Post #664511 15th Nov 2017 1:23pm
Clive
Might just be worth checking the wheel or swivel bearings for play, the sensor is a push fit into it's hole and if you get a bit of movement in the bearing it can cause the ABS ring to push the sensor out of line, I had this on mine when the lower swivel bearing fell apart.
Once fixed and back together I just had to gently tap the sensor down until it was in the right place, it only takes a mm or so between working and not.
Post #664522 15th Nov 2017 2:01pm
bankz5152
Thats the plan for this evening!
Pretty sure the swivels are alright, checked them myself a while a go found no play and just went through an MOT nothing mentioned.
Post #664525 15th Nov 2017 2:12pm
LinDens90XS
2003 Defender 90 Td5 XS CSW Bonatti Grey
mine is an 2003 TD5 90, have had for some time front left sensor turning on the lights. Bearing has been changed and I think that it was packed with too much grease as quite regularly the sensor kept raising a fraction and triggering the warning lights.
Just keep tapping it back into place and all is well for a while (just make sure first that their is no rust pushing the sensor up and always use a piece of timber on the sensor when tapping back with a hammer). hope this helps. Regards
Dennis.
Post #664665 15th Nov 2017 9:24pm
