Home > Technical > 2004 Defender ABS Sensor |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2169 |
My front right ABS sensor keeps tripping out, according to the Nanocom its "electrical failure" and "intermittent XXX times"
I assume I need a new one, though not 100% sure which one! This the right one? https://www.ebay.co.uk/itm/Genuine-Land-Ro...Swh3NZgaoj Or this one? [img]https://www.ebay.co.uk/itm/LANDROVER-DEFENDER-ABS-SENSOR-FRONT-SSW500050-GENUINE-LANDROVER-PART-DEF-TD5/262501773788?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649[/img] Two different part numbers! Two different prices but the same make... Any help? |
15th Nov 2017 11:38am |
So Disco/Def arnt interchangable?
15th Nov 2017 12:35pm |
up date also that price is good Gen LR £265 + VAT and P&P
15th Nov 2017 12:39pm |
interchangeable up to build date |
15th Nov 2017 12:42pm |
Ahhh excellent! Thank you
15th Nov 2017 1:23pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Might just be worth checking the wheel or swivel bearings for play, the sensor is a push fit into it's hole and if you get a bit of movement in the bearing it can cause the ABS ring to push the sensor out of line, I had this on mine when the lower swivel bearing fell apart.
Once fixed and back together I just had to gently tap the sensor down until it was in the right place, it only takes a mm or so between working and not. |
15th Nov 2017 2:01pm |
Thats the plan for this evening!
Pretty sure the swivels are alright, checked them myself a while a go found no play and just went through an MOT nothing mentioned. |
15th Nov 2017 2:12pm |
LinDens90XS Member Since: 24 Feb 2012 Location: Merseyside Posts: 83 |
mine is an 2003 TD5 90, have had for some time front left sensor turning on the lights. Bearing has been changed and I think that it was packed with too much grease as quite regularly the sensor kept raising a fraction and triggering the warning lights.
Just keep tapping it back into place and all is well for a while (just make sure first that their is no rust pushing the sensor up and always use a piece of timber on the sensor when tapping back with a hammer). hope this helps. Regards Dennis. |
15th Nov 2017 9:24pm |
