![]() | Home > Tdi > Wiring help |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1117 ![]() ![]() ![]() |
Anyone with 300tdi,that tell me where to tap info the rear heated widow circuit,can't find anything in the rear end of the loom, got the wiring at the fuse , switch ,relay ,dash warning light ,but from their nothing .
![]() I think from the wiring diagram ,it should black/white wire . |
Thanks ,got that ,but can't find anything at the rear of the 90
you will have it dreckly
![]() Click image to enlarge you can see BW wire to C395 in the pic and then up to door and heated screen |
Your a star , many many thanks , I have no BW wire as shown in the pic
if you have look at second pic down from top witch is engine bay end of the chassis loom C378 plug pin 2 have look and see if WB wire are in place at this point on ever side connector if its missing chassis loom add wire with conduit down chassis
Ok will do tomorrow, thanks
Yep sorted , w/b went to number 2 in the white plug and where it stopped.
Many thanks |
good or not good but latest you no, see if Paul mc can help you with your missing wiring he has mad up looms and parts of looms in the past he on the forum or see below for contact information
Paul mc Phone:07806 381223 Email:lr_connectors@btinternet.com |
