Home > Tdi > Wiring help
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Wiring help
Anyone with 300tdi,that tell me where to tap info the rear heated widow circuit,can't find anything in the rear end of the loom, got the wiring at the fuse , switch ,relay ,dash warning light ,but from their nothing . Confused
I think from the wiring diagram ,it should black/white wire .
Post #664005 13th Nov 2017 6:34pm
dorsetsmith
Post #664010 13th Nov 2017 6:49pm
tolley
Thanks ,got that ,but can't find anything at the rear of the 90
Post #664012 13th Nov 2017 6:58pm
dorsetsmith
you will have it dreckly
Post #664015 13th Nov 2017 7:00pm
dorsetsmith
you can see BW wire to C395 in the pic and then up to door and heated screen
Post #664020 13th Nov 2017 7:08pm
tolley
Your a star , many many thanks , I have no BW wire as shown in the pic Big Cry
Post #664034 13th Nov 2017 8:09pm
dorsetsmith
if you have look at second pic down from top witch is engine bay end of the chassis loom C378 plug pin 2 have look and see if WB wire are in place at this point on ever side connector if its missing chassis loom add wire with conduit down chassis
Post #664036 13th Nov 2017 8:18pm
tolley
Ok will do tomorrow, thanks Thumbs Up
Post #664045 13th Nov 2017 8:32pm
tolley
Yep sorted , w/b went to number 2 in the white plug and where it stopped.
Many thanks
Post #665393 18th Nov 2017 8:31pm
dorsetsmith
good or not good but latest you no, see if Paul mc can help you with your missing wiring he has mad up looms and parts of looms in the past he on the forum or see below for contact information
Paul mc
Phone:07806 381223
Email:lr_connectors@btinternet.com
Post #665396 18th Nov 2017 8:47pm
