Home > Maintenance & Modifications > Twisted mesh grille |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2954 |
11th Nov 2017 1:27am |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
That's their other product which only fits 07 onwards defenders I believe, same as the Zunsport grill
I did find this which is growing on me: Click image to enlarge http://www.4x4overlander.com/product/nakat...-silver-2/ Are there any LR badges that would easily mount on that? Ideally I would still like to get that old school mesh effect like the twisted pic in my original post 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
11th Nov 2017 1:33am |
5 POT Member Since: 24 Nov 2014 Location: UK Posts: 81 |
I think the difference for their new style mesh is it has to fit with an air con panel. That mesh in your photo was just some wire mesh painted and drilled through the panel - I am sure DIY? I asked them about it before on my non air con td5. Problem is I didn't want any of the fixings showing on the front which is why their newer grille is better as no fixings are shown.
That is the Naka grille you can get from 4x4 Overlander in the other photo. I suppose you could put two holes in the heritage badge and just attach with bolts throught the grille? |
11th Nov 2017 10:31am |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 |
My Nakatanenga Heritage grill with Artmin alloy badge.
Fitted the grill in late 2010 but after just a couple of years there were already some spots of corrosion which had to be treated. Bought the badge from Gavin in 2013, as many on here will testify his work is excellent. Click image to enlarge ONE LIFE, GET IT! |
11th Nov 2017 5:59pm |
I think i've worked out a way of doing it myself to achieve the same finish as the retro grill in my original post, i'm going to see if I can buy a spare front panel off ebay to experiment.
Twisted came back to me today (good customer service!) to tell me it was a custom job they did which lead to their stage one grille package.
Do you have anymore photos please Litch? 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
11th Nov 2017 10:59pm |
"Do you have anymore photos please Litch?"
Photos of..........................? ONE LIFE, GET IT! |
12th Nov 2017 8:20pm |
Showcasing that black grille 1993 200 Tdi 90 CSW
12th Nov 2017 9:11pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
A similar one here which I have been considering https://www.ebay.co.uk/itm/Landrover-Defen...1438.l2649
It looks very similar to the Zunsport version, albeit it a lot cheaper. 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
13th Nov 2017 1:12pm |
Here you go Kit
Click image to enlarge Black Heritage grill alongside black heritage light surrounds. Below the Heritage grill is a Nakatanenga discrete winch bumper with a Superwinch fitted A sideways view Click image to enlarge Brendan |
13th Nov 2017 8:39pm |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 220 |
Some 1" square stainless steel welded mesh gives the same effect as the twisted grill. The stuff I used is 3mm diameter mesh with a strip of white plastic edging around it. Would be just as easy to put the mesh behind the panel and bolt through the original grill holes. 1990 Defender 110 200TDI Camper - now converted to Td5 power
18th Nov 2017 12:59pm |
Click image to enlarge 1990 Defender 110 200TDI Camper - now converted to Td5 power |
18th Nov 2017 1:00pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 |
Looks like that's sucking a dummy Brendan
18th Nov 2017 2:15pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
TMD Tuning and Defender Upgrades (I think it was) also do Series grille sets for Pumas. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
18th Nov 2017 4:21pm |
Mr Fox Member Since: 10 Sep 2011 Location: green & pleasant land Posts: 1038 |
Corrosion on the Nakatanenga grill after a couple of years? I thought their stuff was supposed to be excellent quality. Litch, can I ask how you afixed Gavin’s badge to the grill? It looks like you used rivets but I would have thought the grill mesh was too thin to rivet through? |
18th Nov 2017 4:30pm |
