![]() | Home > Technical > Brakes Squealing like a Pig |
Cheap pads. Sticking caliper piston. Build up of dirt around pads.
As above, try cleaning the pads up and where they sit in the calipers first.
DieselBeast Member Since: 27 Sep 2017 Location: UK Posts: 33 ![]() ![]() |
Some pads come with a rattle plate behind each pad which sometimes isn't fitted. Can pop a dab of copper grease on the back of the pad and that should help.
Side note. I've looked at one before that had horrendous squeal, The brake servo wasn't working properly. Might be a thought if you've noticed the brakes aren't quite as good as usual. |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
What make/brand of brake pads have you got fitted? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
Buz Member Since: 24 Jan 2014 Location: Forest of Dean Posts: 238 ![]() ![]() ![]() |
WD40
acuss01 Member Since: 27 Jun 2014 Location: London Posts: 225 ![]() ![]() ![]() |
I had exactly the same on my Defender at 12k miles, drove us crazy. Thought it might be dirt/grit from offroading on Salisbury.
Garage took a look at it and (I think) they sprayed a lubricant like WD40. However problem persisted. On my next visit to garage they used the copper grease. Problem went away... well, except for the occasion squeak. 2015 110 XS CSW Montalcino Red with Black Pack |
bogwert Member Since: 02 Sep 2016 Location: Dundee Posts: 194 ![]() ![]() ![]() |
![]() ![]() I'd look at the amount of copper grease on the back of the pads. Might just be as simple as taking them out, re-grease and refit? also... while you have them out, stick a few pieces of wood in the gap between the disc and pad. Press the break pedal and ensure the pistons are moving freely and are clean. Chris 2014 Discovery 4 TDV6 HSE 2003 Defender 90 TD5 CSW ![]() |
