Home > Technical > defender issues |
ChrisJ Member Since: 12 Nov 2013 Location: Warwickshire Posts: 231 |
I had a loose barrel on my rear door, in my case it was just a case of rotating the barrel in the handle and it "clicked" into place, I think it had been located the wrong way round when made.
With regards to your missing one, have a good look in the barrel hole to see if any things missing or broken, if not a new barrel should do the job, it may be worth replacing all locks so you have a matching key for all locks. |
13th Oct 2017 9:29pm |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 |
What year is the car ? has it the small lock barrels ? I might have some new ones with keys will look
14th Oct 2017 9:50am |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1230 |
Hi
from memory there is a small spring loaded pin which locates in the body of the handle. To remove you put a small screwdriver in which releases the key barrel. In practice they seize up which causes all sorts of fun to remove. All that happens from inside the door (meaning you need to remove the trim). Yours sounds like the reverse. pin not extending and locking into place. |
14th Oct 2017 10:55am |
scot the sniper Member Since: 13 Oct 2017 Location: dundee Posts: 2 |
cheers foxy much appriciated. its a v reg |
14th Oct 2017 12:47pm |
