![]() | Home > V8 > LS3 |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
Contacted a company called TopHat, who have two sites in the US and one in Holland, to see what a Euro price might be on an LS3 conversion. It seems they only do a full conversion, here's what they offer. (Note this only offers a manual transmission, no Recaros, no sound upgrade and no leather trim etc):
LS3 drive train upgrade includes: - Engine Assembly, LS3 Long Blk - Oil Pan Assembly, LS2/LS3 Style - Harmonic Balancer, Pioneer LS3/Truck - Type, 8 Rib, 10% Overdrive Black - Intake Manifold Assembly, LS3 Style - Thermostat, 186 Degree - Billet Water Neck foThermostat - Water Pump Assembly, Camaro Style - Alternator - Power Steering Pump Set, Camaro - Coil Pack Assemblies, LS2/LS3/LS7 - ECM, GM E38 - Wiring Harness, LS3/7 58T - Flywheel - Dual plate clutch - Air Filter, K&N RC-4680 LS14in - Coil Cover Kits, LS3 Black - Starter, All LS inc shield - T56 Magnum 6 speed manual transmission - Stainless steel fuel lines - Bosch Fuel Filter Assembly - High flow fuel pump - Holley Fuel Pressure Regulator - Stainless steel braided fuel hoses - Upgraded Tophat transfer case - Limited slip differentials front, rear and in the transfer case - Upgraded heavy duty halfshafts, CV joints and drive flanges - High performance AP front and rear disc brake upgrade for 18" wheels - 364mm vented and grooved discs with 6 pot calipers in front - 330mm vented and grooved discs with 4 pot calipers in rear - Stainless steel brake lines - Stainless steel fuel lines - Tophat oil filled engine mounts to eliminate engine vibrations - Tophat transmission and transfer case mountings - Heavy duty anti roll bars - Upgraded Tophat cooling system - Tophat custom oil cooler - Tophat custom transmission cooler - Power steering cooler - Sanden AC compressor - High performance fuel system - Custom stainless steel full exhaust system with headers - Improved steering geometry - special KONI/TOPHAT shock absorbers - Air suspension or coil springs - Upgraded thermal and accoustic insulation - Custom air intake - 18" wheels of choice - Cooper ZEON LTZ 285-60-18 tires - Rear Radius arms - Front radius arms - A frame - Panhard rod - HD Steering arm and track rod - New steering box - Disco 1 drop arm - Upgraded steering damper - 30mm wheel spacers - Front drive shaft - Rear drive shaft - Upgraded swivel housing with upper and lower swivel pin bearings - Front and rear stub axles - Upgraded front and rear drive flanges - Front and rear wheel bearings - Front and rear flanges - Speed pick up sensor - Upgraded transfer case with sleeved casing and limited slip diff - Upgraded front and rear pegged differentials with limited slip diff - All bushes, rubbers, bolts, nuts, washers, etc. Here's their price €95.000,00 ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
You can't fault their work or their pride in it though. Here are some shots they sent me:
![]() ![]() ![]() ![]() Click image to enlarge ![]() ![]() Click image to enlarge ![]() ![]() ![]() Click image to enlarge ![]() ![]() ![]() Click image to enlarge ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() ![]() ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7918 ![]() ![]() ![]() |
Ouch that price! But when you see this photo, you realise what's involved!!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 ![]() ![]() |
Very detailed conversion, whopping price tag tho
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
worth a look... credible outfit by the looks of it...
SKIP https://www.defender2.net/forum/topic83242.html |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
I love the TopHat stuff EXCEPT I hate KBX front ends, they are just hideous,but I suppose people need to know that your car is 'bespoke' somehow
![]() Other than that, the ragtop is perfect, I like the alloys on it too. Hats off to them. |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
I like some of the KBX front ends but I don't like that one with the mesh in it, I like yellow on a ragtop, not so much for a hardtop though 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6328 ![]() ![]() ![]() |
air suspension too.
I personally would have preferred the mirror arms to remain black......... Looove the 110 ![]() ![]() |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2943 ![]() ![]() |
Listening to these going through the gears, manual is def the best option Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
