Home > V8 > LS3
Page 3 of 3 <123
Grenadier
Contacted a company called TopHat, who have two sites in the US and one in Holland, to see what a Euro price might be on an LS3 conversion. It seems they only do a full conversion, here's what they offer. (Note this only offers a manual transmission, no Recaros, no sound upgrade and no leather trim etc):
LS3 drive train upgrade includes:
- Engine Assembly, LS3 Long Blk
- Oil Pan Assembly, LS2/LS3 Style
- Harmonic Balancer, Pioneer LS3/Truck
- Type, 8 Rib, 10% Overdrive Black
- Intake Manifold Assembly, LS3 Style
- Thermostat, 186 Degree
- Billet Water Neck foThermostat
- Water Pump Assembly, Camaro Style
- Alternator
- Power Steering Pump Set, Camaro
- Coil Pack Assemblies, LS2/LS3/LS7
- ECM, GM E38
- Wiring Harness, LS3/7 58T
- Flywheel
- Dual plate clutch
- Air Filter, K&N RC-4680 LS14in
- Coil Cover Kits, LS3 Black
- Starter, All LS inc shield
- T56 Magnum 6 speed manual transmission
- Stainless steel fuel lines
- Bosch Fuel Filter Assembly
- High flow fuel pump
- Holley Fuel Pressure Regulator
- Stainless steel braided fuel hoses
- Upgraded Tophat transfer case
- Limited slip differentials front, rear and in the transfer case
- Upgraded heavy duty halfshafts, CV joints and drive flanges
- High performance AP front and rear disc brake upgrade for 18" wheels
- 364mm vented and grooved discs with 6 pot calipers in front
- 330mm vented and grooved discs with 4 pot calipers in rear
- Stainless steel brake lines
- Tophat oil filled engine mounts to eliminate engine vibrations
- Tophat transmission and transfer case mountings
- Heavy duty anti roll bars
- Upgraded Tophat cooling system
- Tophat custom oil cooler
- Tophat custom transmission cooler
- Power steering cooler
- Sanden AC compressor
- High performance fuel system
- Custom stainless steel full exhaust system with headers
- Improved steering geometry
- special KONI/TOPHAT shock absorbers
- Air suspension or coil springs
- Upgraded thermal and accoustic insulation
- Custom air intake
- 18" wheels of choice
- Cooper ZEON LTZ 285-60-18 tires
- Rear Radius arms
- Front radius arms
- A frame
- Panhard rod
- HD Steering arm and track rod
- New steering box
- Disco 1 drop arm
- Upgraded steering damper
- 30mm wheel spacers
- Front drive shaft
- Rear drive shaft
- Upgraded swivel housing with upper and lower swivel pin bearings
- Front and rear stub axles
- Upgraded front and rear drive flanges
- Front and rear wheel bearings
- Front and rear flanges
- Speed pick up sensor
- Upgraded transfer case with sleeved casing and limited slip diff
- Upgraded front and rear pegged differentials with limited slip diff
- All bushes, rubbers, bolts, nuts, washers, etc.
Here's their price
�95.000,00 Shocked Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #659587 25th Oct 2017 2:35pm
Grenadier
You can't fault their work or their pride in it though. Here are some shots they sent me:
Post #659594 25th Oct 2017 3:08pm
JOW240725
Ouch that price! But when you see this photo, you realise what's involved!!
 James
Instagram @suffolk_rovers
Post #659663 25th Oct 2017 8:19pm
Pickles
Love it, extremely comprehensive, HUGE dollars, but I guess that you "get what you pay for",...well hopefully you do.
Pickles.
Post #659687 25th Oct 2017 9:16pm
Coatesyyy
Very detailed conversion, whopping price tag tho Shocked Laughing
Post #661457 2nd Nov 2017 5:00pm
X4SKP
worth a look... credible outfit by the looks of it...
 SKIP
Post #661464 2nd Nov 2017 5:54pm
I love the TopHat stuff EXCEPT I hate KBX front ends, they are just hideous,but I suppose people need to know that your car is 'bespoke' somehow Rolling Eyes I'm not much for the logo on the steering wheel either, a bit naff.
Other than that, the ragtop is perfect, I like the alloys on it too.
Hats off to them.
Post #661467 2nd Nov 2017 6:10pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I like some of the KBX front ends but I don't like that one with the mesh in it, I like yellow on a ragtop, not so much for a hardtop though 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #661484 2nd Nov 2017 7:16pm
Caterham
air suspension too.
I personally would have preferred the mirror arms to remain black.........
Looove the 110 Thumbs Up Bow down
Post #661632 3rd Nov 2017 12:49pm
mcma1
Listening to these going through the gears, manual is def the best option Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #661790 4th Nov 2017 9:11am
Page 3 of 3 <123
