Home > Wheels & Tyres > Spare wheel mounted to back door hits panel when opened...
hugh_b
Hi everyone,
I noticed the other day whilst fitting a stainless bolt kit on my back door that when fully opened the spare wheel hits the body panel. It would seem that the stopper doesn't work/has broken or i just didn't notice it before.
Is there and easy fix for this such as an adjustment or replacement part?
Thanks
Hugh
Post #61358 27th Feb 2011 9:40pm
Lorryman100
If you look at the bottom left hand corner of the above photo you will see two nuts. These come loose and need to be tightened periodically. Remove the close bar from the door and pull the trim off to gain access.
Post #61362 27th Feb 2011 9:45pm
hugh_b
many thanks! Will give it a go tomorrow Smile
Post #61364 27th Feb 2011 10:00pm
K9F
If you look carefully it's amazing how many newish Defenders have a dent in the offside panel for that very reason! Fortunately with the offset of my wheels this problem is no longer an issue as the wheel sits further away from the rear door! I can also now clean behind easily too! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #61365 27th Feb 2011 10:18pm
hugh_b
Went to tighten the two nuts this evening but have found that someone has "attempted" before and the threads were so mashed that i struggled to get the nuts off!
Anyway, i've tried to search for replacement part but not sure what i should be searching for, any ideas (it;s the little metal plate with the two threaded stubs coming out of it).
Thanks
Hugh
Post #61507 28th Feb 2011 8:15pm
Lorryman100
Hugh,
The bit you are after is, BFU710200 Stud Bolt.
Post #61518 28th Feb 2011 8:32pm
hugh_b
Excellent, just ordered!
Very Happy
Post #61529 28th Feb 2011 9:01pm
leeds
Also the Nakatanega gas strut door stay is now available in the UK!
Have a look HERE
It will finally get on our website when my IT guru has time from her other duties.
Brendan
Post #61531 28th Feb 2011 9:03pm
