Home > Puma (Tdci) > 2011 defender 90 |
yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230 |
Anything to look for when buying a 2011? It's done 56000.
Thanks |
5th Oct 2017 6:43pm |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
It should be pretty good TBH.
All the usual things S/H Chassis Bulkhead Put into low range Good luck |
5th Oct 2017 6:55pm |
zs1sam Member Since: 21 Jun 2013 Location: Cape Town Posts: 30 |
Check the output shaft from gearbox to transfer case. Well documented weakness in that it strips and you then go nowhere!
ZS1SAM Simonstown RSA |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello yanto
Recently covered and relevant...good luck too http://www.defender2.net/forum/topic57168.html SKIP https://www.defender2.net/forum/topic83242.html |
5th Oct 2017 7:00pm |
