Home > My Defender > Mariner's 200Tdi 90
Page 3 of 6 <123456>
Retroanaconda
They’re all the same width. It’s probably warped slightly either during welding repairs or galvanising.
I’d get a jack between one leg and the chassis and just stretch it to fit.
Post #709251 26th May 2018 6:54am
Mariner
Ireland
Thanks Retro,
That's a much better suggestion than any of mine Thumbs Up Bow down Bow down
I'll go and wrestle with it this morning.
I guess I should have gone about the fitting early in the day when more alert and thinking straight.
Post #709257 26th May 2018 7:18am
Mariner
Ireland
Well today turned out better than I expected after last nights drama.
I got the bulkhead mounted following advice from Retroanaconda. All the bolts bar the first needed some persuasion to fit in place. I also got the sill rails fitted. The passenger side looks good but the upper part of the drivers side needs to go forward a touch.
While all that was going on I had a visit from a friend who was clearing out his garage having sold 2 90s. He gave me a full tilt and hoop set that had been lying unused for several years. So I now have the option of canvas, truck cab or hard top!!
The dog had a walk, the grass was cut and Leinster won the Guinness Pro14.
So all told a good days work.
Post #709354 26th May 2018 7:48pm
L110CDL
Taking shape now and looking good Thumbs Up Clayton.
Keeper.
Post #710047 30th May 2018 9:39pm
Mariner
Ireland
So I made a start on the build a while ago but progress has been slow rather than spectacular.
Floors in, sills on and doors trial fitted.
Spent a lot of time on the gearbox cover, trimming to fit and easing screw holes to line up with plugs.
Had to clean excess galv from the pillars in order to get the hinge bolt captive nuts in.
The stainless nuts are slightly larger than the mild steel version so I shaved a little off each side of the nut before giving the cage a squeeze in the vice in order to get them into the pillar.
All very time consuming.
Hopefully I can keep up the momentum and get a bit more done.
Post #746497 19th Dec 2018 7:54pm
L110CDL
Looking good there Thumbs Up Clayton.
Keeper.
Post #746827 21st Dec 2018 9:40pm
Mariner
Ireland
Managed to fit clutch, brake, accelerator pedals and steering column.
Tidied up the loom at the back of the engine and got the fuel filter mounted again.
One less box of bits on the floor and all the bolts found a home (eventually).
Post #749222 4th Jan 2019 6:26pm
Co1
This is looking great! Have you got a finish date in mind?
Post #749225 4th Jan 2019 6:37pm
Mariner
Ireland
Hope to have her back on the road for the summer but I thought the same this time last year Shocked
I was never one for targets and deadlines. Smile
Post #749227 4th Jan 2019 6:47pm
Co1
😂 been there! Once took a kitchen That should have taken a weekend and we were still washing up in the bath 4 months later. Wife was less than amused!
Post #749230 4th Jan 2019 6:57pm
Mariner
Ireland
Fitted the heater box today together with a new seal to the bulkhead.
Seemed like a simple enough job but the new seal made it a bit more difficult than expected.
It's not a task that I would want to do with all the bodywork in place.
Post #749410 5th Jan 2019 5:08pm
JOW240725
Wow, only just seen this great thread. Awesome work, it looks amazing Cool Thumbs Up Bow down James
Instagram @suffolk_rovers
Post #749422 5th Jan 2019 6:15pm
JOW240725
Only just seen this thread, wow amazing work! She's going to look stunning! Cool Thumbs Up James
Post #749423 5th Jan 2019 6:16pm
JOW240725
Sorry Embarassed James
Post #749424 5th Jan 2019 6:17pm
Mariner
Ireland
While I have been working on the 90 I noticed that the radiator had a slight weep.
Only a small amount of coolant leaked over the past year but I decided to deal with it while everything was stripped down.
I took the rad out and on close inspection the core was badly corroded.
I brought it to Carlow Radiators at lunch time Thursday and they carried out the recore
and the courier delivered back to me on Saturday morning. Great service.
I took the opportunity to clean and paint the rad frame, cooler ducting, fan cowl, chassis etc.
Reinstalled it all today with new hose clips and coolant.
Hopefully one less thing to worry about when out and about in future.
Back to the rebuild now Smile
Post #754869 29th Jan 2019 8:57pm
