Home > INEOS Grenadier > Main Grenadier discussion thread
Page 48 of 118 <123 ... 474849 ... 116117118>
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Supacat wrote:
A couple from Instagram, first open view of the natty feature on the spare wheel:
Is that a redesigned rear underbody protection guard to replace the previous scoop / sand anchor?
It looks a lot neater.
Post #913221 20th Jul 2021 12:11pm
Supacat wrote:
What's the "tank" arrowed here?
My immediate thought, based on shape and the type of connector, is that it is a fuel filter or something of that ilk.
Re. the tyre pressure monitoring, as noted above some form of TPMS is now mandatory (since motorists are now too stupid/incapable/bone idle to check their tyre pressures), but it could be an in-tyre device or interpolated from wheel speed.
Too much, I suppose, to hope for an optional proper central tyre inflation system on the vehicle!
Post #913228 20th Jul 2021 1:00pm
spudfan
Ireland
I have been following this from the start and I am happy with the direction the vehicle has taken. It seems they are concentrating on good solid engineering over styling rather like the early Land Rovers. Fair enough the styling was taken from a Defender when Mr Radcliffe said that was the type of vehicle he liked and wanted. If Land Rover won't make it for him he'd make his own.
I never had a problem with the Land Rover rear door and despite the Grenadier having a wider door opening at the back it still only takes a euro pallet in the back the same as the Defender. I like the dash Land Rover used from the 90/110 through to the revamped Puma version so the Grenadier dash, though still in development, would take a bit of getting used to especially with the large screen in the centre.
Land Rover nailed it with the seperate seat base as bases wear quicker than the seats. It is easier and cheaper to replace a base than a whole seat so I had hoped Grenadier would follow this tradition.
I know it will come in at a higher price point than the 90/110 type Defender but that is due to the high quality and strength of the compnents. If Land Rover had revamped their 90/110 type Defender in this direction I would have been happy with a similar price point for it.
I would like a manual gearbox as that is all I have driven. Anyway I like it and like everyone else I look forward to the on sale version.
By the way, is the Grenadier permanent four wheel drive like the 90/110 and Puma? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #913233 20th Jul 2021 1:38pm
Good question! I do hope so, since in my opinion that is one of the great strengths of the classic Defender - full-time 4WD with a proper centre diff, rather than either part-time or a crappy Haldex-type unit.
Post #913234 20th Jul 2021 2:16pm
County V8
Yes permanent 4WD with locking centre differential
Post #913238 20th Jul 2021 3:44pm
spudfan wrote:
Land Rover nailed it with the seperate seat base as bases wear quicker than the seats. It is easier and cheaper to replace a base than a whole seat so I had hoped Grenadier would follow this tradition.?
I would have though the removable seat base (on a defender) was just to facilitate acces to the batteries & fusebox, not for any help in changing worn out bases.
Post #913247 20th Jul 2021 4:24pm
spudfan
Ireland
Thumbs Up
"I would have though the removable seat base (on a defender) was just to facilitate acces to the batteries & fusebox, not for any help in changing worn out bases."
Probably but it is an added bonus to be able to swap them over or replace them. They are also handy for sitting on when removed from the vehicle! 1982 88" 2.25 diesel
Post #913249 20th Jul 2021 4:43pm
County V8 wrote:
Looks to have the word MAHLE on it they make filters etc
Seems to be the consensus Thumbs Up
It wasn't there on earlier photos, but then there appears to be lots of things they haven't made final decisions on, which is all good.
Post #913257 20th Jul 2021 5:12pm
Bluest
A question which has just occurred to me, but don’t think has been discussed. Does the BMW diesel have a self priming fuel system? Must be someone on here who has said the same engine in a BMW who may know. 2007 110 TDCi Station Wagon XS
Post #913259 20th Jul 2021 5:23pm
So another question.
What type of coupling is this?
It's certainly looks different from the open universal joints on earlier prototypes:
Post #913260 20th Jul 2021 5:24pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Some sort of diaphragm connector. I hope someone can give an exact type. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #913278 20th Jul 2021 6:33pm
Bluest
Looks a bit like the old rotoflex couplings from the olden days. The prop does look very skinny where it goes into 5hr coupling. 2007 110 TDCi Station Wagon XS
Post #913281 20th Jul 2021 6:44pm
markb110
spudfan wrote:
Thumbs Up
Not to mention you could take them out then sit with your back against a wheel whilst enjoying a drink of some description..... Very Happy
Post #913287 20th Jul 2021 7:34pm
spudfan
Ireland
Yep that was one of my points mentioned above. Thumbs Up 1982 88" 2.25 diesel
Post #913290 20th Jul 2021 7:39pm
ickle
The driveshaft coupling looks like the cv joints I had on my beach buggy back in the day (open driveshaft type not swing axle)
Post #913294 20th Jul 2021 8:04pm
