Home > Puma (Tdci) > Defender Puma 2.4 Overheating
IMHO the overheating is caused by:
this is normal, just drive the car and enjoy
33%
 33%  [5]
it seems that the radiator is clogged - change the radiator
6%
 6%  [1]
it seems that the watr pump is dying - change the water pump
13%
 13%  [2]
it seems that the lower coolant hose is collapsing - put a new hose
6%
 6%  [1]
your CHT sensor is crazy - change the sensor
0%
 0%  [0]
all above is a waste of money - your head gasket is broken and needs changing
40%
 40%  [6]
Total Votes: 15
Page 2 of 3 <123>
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
So, finally I was able to change the belt and make a highway test.
While driving 120-130km/h the temperatures stayed in the 88-100°C range. The 100°C was reached only sometimes and it was dropping.
The only problem is that now the ambient temperatures are between +10°C and +25°C so it's difficult to compare. Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #688424 23rd Feb 2018 1:40pm
Bergos
Can anyone tell me what are the normal temperature ranges for a healthy Defender Puma 2.4 depending on the ambient temperatures?
How much does the ambient temperature influence a hot engine while driving on a highway? Bergos
Post #688440 23rd Feb 2018 2:49pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
When I’m on a good motorway run, sitting between 75/80mph
My Ultragauge is constantly reading between 85, 90 degrees.
It never goes over 90 deg. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #688442 23rd Feb 2018 3:06pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Mine goes higher than that, it fluctuates between 88°C and 98°C, most of the time sitting around 93°C.
Considering that the standard thermostat starts opening at 88°C, I reckon this range of temperature is to be expected, unless you change the thermostat for one that opens earlier (like PEL500110) maybe? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #688443 23rd Feb 2018 3:11pm
ian series 1
Mine does run slightly cooler since fitting bigger intercooler. 80" 80" 86" 88" 90"
Post #688447 23rd Feb 2018 3:24pm
o4dn
Ah right, makes sense, mine is completely standard... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #688448 23rd Feb 2018 3:25pm
Bergos
Ok. So now, during the Portuguese winter mine is between 88-100 while driving 130 km/h.
If I drive 100 it's definitely lower.
For now I will assume that the problem is fixed and I will see what will happen in summer.
Thank you. Bergos
Post #688449 23rd Feb 2018 3:38pm
Bergos
Ahhh... I also see that the average charging voltage is 0.5V higher than before.
Seems to confirm the "belt theory". Smile Bergos
Post #688450 23rd Feb 2018 3:40pm
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Mine does goes above 100 degrees when climbing for a long time .
When i drove to Portugal for xmas the ultragauge was always reading between 80 and 93 but in Spain we had to climb some long hills and the temperature got to 103.
This when the outside temperatures were 5 or 6 degrees.
It will be interesting to see what sort of temperatures the ultragauge shows when i go camping to Italy this summer.
Fabio
Post #688473 23rd Feb 2018 5:56pm
Bergos
OK, guys!
Seems that after 4 years of struggling, stressing and following crazy theories, the problem has been solved! Finally. Well those theories seem crazy now, in hindsight...
Anyway, to make the long story short, I replaced the radiator 2 days ago (and the water pump, but it seemed to be completely fine). Since then the temperature went to 95 degrees maybe once on a long uphill highway while driving in the 6th gear. I did this on purpose to stress the engine and see how high the temp will go. Besides this the temperatures keep in the 78-88 degree range!
So, yes, seems that the radiator was clogged...
Also - normal temperatures should not exceed 95 deg. even under load.
Also - the fuel economy is back to normal!!! Bergos
Post #931995 1st Dec 2021 10:19am
Naks
Ola, como estas?
Thanks for the feedback Thumbs Up --
Post #932022 1st Dec 2021 11:50am
Bergos
Sad epilogue...
Unfortunately, this story has a follow up.
Sunday I went on a trip from Lisbon to Warsaw.
Temperatures up to 40°C.
Sunday - all good.
Monday - the car overhead on a highway and I also noticed a strange noise at higher revs. Engine stopped when I pulled over. I needed to wait for the engine temperature to drop before I could start it again. I topped the engine oil.
Tuesday - in the afternoon the engine started to cut off, power loss, difficulty starting. Finally it died on a country road. Has not started again.
Turbo shaft very loose. Oil disappeared through the turbo.
I am afraid that my engine is a piece of junk now.
Towing the Def to Poland - €2000 for starters... Bergos
Post #1005320 24th Aug 2023 4:01pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
Oh no, that's not good news Sad Hope you get it all sorted.
Post #1005391 25th Aug 2023 8:45am
spudfan
Ireland
Sometime ago our 2008 2.4 was cutting out and the temperature gauge would rise. Turned out to be a loose hose clip on one of the cooling system hoses, Water/coolant was escaping and the vehicle has an in built safety mechanism to shut off if the temperature goes above a certain level. It will restart when the temperature drops to normal. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1005561 27th Aug 2023 12:30pm
Bergos
Good news today - seems that the engine itself survived and I might be lucky to sort it out just by replacing the turbo! Bergos
Post #1005673 28th Aug 2023 8:28pm
Page 2 of 3 <123>
