![]() | Home > Puma (Tdci) > Fuel line mod - adding another fuel filter |
Bushpig Member Since: 07 Nov 2013 Location: Risca, Wales Posts: 236 ![]() ![]() ![]() |
The racor I've fitted is also 2 micron and have yet to pick up any particles or water.
Presume the diesel quality down here is not that bad then... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so. Douglas Adams 2012 2.2 Puma |
Simon.pl Member Since: 15 Mar 2016 Location: Warsaw Posts: 98 ![]() ![]() ![]() |
Does anyone know what is the inner diameter of the feed and returning fuel lines between tank and fuel filter?
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 ![]() ![]() |
Hi there
I have seen a few defenders down here installed a secondary fuel filter And I am about to do the same Its location is above the mid cross member near the fuel cooler Check out this website $425 comes everything you need, including a bash guard Cheefs http://www.dieselcare.com.au/product/filtr...it-dcs029/ ![]() Click image to enlarge |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
Hi Simon, sorry for the slow response I've been away for a few weeks. A colleague at work sent me a couple of pictures of the fitting instructions, let me know if you'd like anymore info. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Thanks chaps!
I just decided to follow my way and installed the filter under the rear fender. Will make some kind of shield there of course to protect the filter. ![]() Click image to enlarge Using a hose bender and Tekalan (PA12) hoses made new fuel lines. Used 10/8 Tekalan hose for return and 12/9 for feed. Bought some quick release connectors that I found locally - 7,89 for the return and 9.89 for the feed line. What interesting - only on the filter base the feed line has a bigger connector. On the tank side both connectors are the same. I didn't heat hoses up to push the connectors in - I used the silicone gun instead making a press of it. In my opinion it is much better fitment than when using heat (Tekalan doesn't return fully to its previous diameter when heated up). I have wrapped the feed hoses with red shrinking tube and return with the black one for extra protection. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge There is a three way connector on the return pipe close to the tank as I have made additional fuel tank and this is a line that feeds the main one from the additional tank. ![]() |
