Home > Puma (Tdci) > Fuel line mod - adding another fuel filter
Page 2 of 2 <12
Simon.pl
Poland 2007 Defender 110 Puma 2.4 HT Keswick Green
Thanks Bushpig,
I just don't see a sense in installation under the hood as it would be after the main filter which is 2 micron filter.
I want the Racor to be first in the line.
Thumbs Up
Post #650021 13th Sep 2017 8:43am
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
The racor I've fitted is also 2 micron and have yet to pick up any particles or water.
Presume the diesel quality down here is not that bad then... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #650030 13th Sep 2017 9:41am
Simon.pl
Does anyone know what is the inner diameter of the feed and returning fuel lines between tank and fuel filter?
Post #650067 13th Sep 2017 12:22pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
Hi there
I have seen a few defenders down here installed a secondary fuel filter
And I am about to do the same
Its location is above the mid cross member near the fuel cooler
Check out this website
$425 comes everything you need, including a bash guard
Cheefs
http://www.dieselcare.com.au/product/filtr...it-dcs029/
Post #651977 22nd Sep 2017 5:47am
tuesdayfox
Post #651978 22nd Sep 2017 5:52am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Simon.pl wrote:
Cheers Harry!
Yes, please do. Any info would be great - especially where they planed to install those pre-filters and how the fuel lines were designed.
Seems like my setup - I also have a LED in the dash for warning and there is 10 micron fuel filter before the main one.
Thumbs Up
Which fuel lines you mean ZSD-PUMA? I mean what are they made of?
Hi Simon, sorry for the slow response I've been away for a few weeks. A colleague at work sent me a couple of pictures of the fitting instructions, let me know if you'd like anymore info.
 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #652671 25th Sep 2017 2:47pm
Simon.pl
Thanks chaps!
I just decided to follow my way and installed the filter under the rear fender. Will make some kind of shield there of course to protect the filter.
Using a hose bender and Tekalan (PA12) hoses made new fuel lines. Used 10/8 Tekalan hose for return and 12/9 for feed. Bought some quick release connectors that I found locally - 7,89 for the return and 9.89 for the feed line. What interesting - only on the filter base the feed line has a bigger connector. On the tank side both connectors are the same.
I didn't heat hoses up to push the connectors in - I used the silicone gun instead making a press of it. In my opinion it is much better fitment than when using heat (Tekalan doesn't return fully to its previous diameter when heated up).
I have wrapped the feed hoses with red shrinking tube and return with the black one for extra protection.
There is a three way connector on the return pipe close to the tank as I have made additional fuel tank and this is a line that feeds the main one from the additional tank.
Thumbs Up
Post #656395 10th Oct 2017 5:42pm
Page 2 of 2 <12
