Home > Technical > Defender td5 won't start... |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1762 |
First step is check battery voltage.
Are there any signs of life, it could be the main relay also? Quite a common issue. |
9th Sep 2017 3:14pm |
Bert@E Member Since: 08 Jan 2016 Location: amsterdam Posts: 63 |
Where is the main relay located, under the seat or in front of the gearbox?
9th Sep 2017 3:53pm |
Under the seat for that one
9th Sep 2017 3:56pm |
Click image to enlarge |
9th Sep 2017 4:12pm |
LinDens90XS Member Since: 24 Feb 2012 Location: Merseyside Posts: 83 |
Just as an aside. Check the wiring colours as the main relay on my 2003 TD5 was in position 2, not 4 as my book said. tried changing it into the correct space but other relays would not reach. Regards
Dennis. |
10th Sep 2017 9:55pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
Assuming you have lights on the dashboard when you turn on the ignition, the only thing stopping the starter turning is the immobiliser or the starter relay. The immobiliser provides an earth for the starter relay when it's disarmed.
The main relay, as it's termed, is for the engine ECU and has no effect on the starter motor circuit on a TD5. Disconnecting the battery and reconnecting it will have armed the immobiliser, are you sure you have disarmed it ? http://www.yorkshireoffroadclub.net/ |
10th Sep 2017 10:16pm |
stigomery Member Since: 10 May 2016 Location: Cambridge Posts: 277 |
When mine did this it was the starter solenoid. No click, no other issues, full battery...
A quick whack with a bit of wood on the starter solenoid soon sorted it out |
11th Sep 2017 8:38pm |
