Home > Td5 > Ashcroft gearbox
Martin 01
Ashcroft gearbox
Need a new gearbox for my Defender.
Going to go with Ashcroft as they seem to be the best & offer a decent warranty.
Just want to know if it is worth the extra money for the upgraded bearings ?
I do tow a caravan from time to time & it does have an Alive map on it.
Also be fitting a new clutch & flywheel at the same time so should all be ok.
Post #646609 27th Aug 2017 5:09pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Not sure on the bearings they will advise I guess but Ashcroft seem to be the best bet Thumbs Up
My Indy recommend there stuff as doing what it says on the tin.
Post #646661 27th Aug 2017 8:59pm
excossack
I got upgrades in my gearbox. Not sure if any better but feel more confident. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #646664 27th Aug 2017 9:01pm
Harry.O
My R380 let go earlier this year due to the carrier bearings so I bought a recon box from Ashcrofts with uprated bearings. No idea if they will last longer although hopefully so. The standard ones are a known weakpoint of the R380 so figured it was worth doing.
I'd recommend their V8 5th gear ratio at the same time Thumbs Up
Post #646736 28th Aug 2017 9:20am
dorsetsmith
output carrier bearings and 5th gear layshaft bearings made by RHP ( SKF ) land rover now using NWB 2515 BC 1410 £90.00 box marked made in chine Rolling Eyes
FTC3371 output carrier RHP RJ2022, FTC2385 5th gear layshaft carrier RHP 2023 or A&S Fersa F19055 Bearing
Post #646769 28th Aug 2017 2:27pm
Brucey
Poland 2004 Defender 110 Td5 DCPU Auto Java Black
If you want to save some cash, I have a 'known good' R380 for sale in FS&W.... Smile
Chris Defender 110 DC converted Auto
BMW R1200GS
BMW F650GS Dakar
Post #647131 30th Aug 2017 8:42am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Have you considered Syncro-Works.
A lot of the Ultra 4 and challenge truck folks are running his gear, and it has proven to be very very durable.
Chris
Post #647134 30th Aug 2017 9:09am
ashtrans
Site Sponsor
These 2 bearings are very important, A&S Fersa and NWB both had failures after 3-4 months if used hard, the original RHP's were OK but not great, they could still fail after 12-18 months but when these were no longer available we got our own made by NKE in Austria , to get these 2 made with their MOQ was £120K, we have not had one fail since we have had them, about 4-5 years, better than RHP by far, note the HD ones we fit are also NKE,
Dave Dave
Post #647484 31st Aug 2017 8:03pm
Martin 01
All sounds good to me Dave.
I need to call tomorrow & get one ordered. Thumbs Up
Post #647505 31st Aug 2017 8:53pm
Martin 01
Chris
No not considered them Chris as never heard of them.
Might take a look though. Thumbs Up
Post #647508 31st Aug 2017 8:56pm
dorsetsmith
Dave
can Ashcroft supply HD output carrier bearing, as RHP bearing no longer available from LR and they are supply NWB 2515 BC 1410 £90.00 box marked made in chine
and if you look at the roller on the NWB 2515 BC 1410 bearing 1/3 smaller so more point load
Post #647553 1st Sep 2017 5:44am
ashtrans
Site Sponsor
Do you mean FTC2385 ? Dave
Post #647568 1st Sep 2017 6:55am
dorsetsmith
FTC3371 output carrier bearing
In the process of rebuilding my R380, order replacement FTC3371 output carrier bearing from LR and was send
NWD bearing as a replacement, box had RHP RJ2022 fitted from new as far as I no.
Post #647569 1st Sep 2017 6:58am
ashtrans
Site Sponsor
yes we have FTC3371 made by NKE which we find better than genuine RHP and way better than NWB or A & S Fersa
Dave Dave
Post #647598 1st Sep 2017 9:41am
dorsetsmith
thanks
Can Ashcroft supply FTC3371, FTC2385 made by NKE ?
Post #647599 1st Sep 2017 9:49am
