![]() | Home > Td5 > Ashcroft gearbox |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Not sure on the bearings they will advise I guess but Ashcroft seem to be the best bet
![]() My Indy recommend there stuff as doing what it says on the tin. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
I got upgrades in my gearbox. Not sure if any better but feel more confident. 1999 Defender TD5 110
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
My R380 let go earlier this year due to the carrier bearings so I bought a recon box from Ashcrofts with uprated bearings. No idea if they will last longer although hopefully so. The standard ones are a known weakpoint of the R380 so figured it was worth doing.
I'd recommend their V8 5th gear ratio at the same time ![]() |
output carrier bearings and 5th gear layshaft bearings made by RHP ( SKF ) land rover now using NWB 2515 BC 1410 £90.00 box marked made in chine
![]() FTC3371 output carrier RHP RJ2022, FTC2385 5th gear layshaft carrier RHP 2023 or A&S Fersa F19055 Bearing |
Brucey Member Since: 18 Jul 2012 Location: Warsaw, Poland Posts: 61 ![]() ![]() ![]() |
If you want to save some cash, I have a 'known good' R380 for sale in FS&W....
![]() Chris Defender 110 DC converted Auto BMW R1200GS BMW F650GS Dakar |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 794 ![]() ![]() ![]() |
Have you considered Syncro-Works.
A lot of the Ultra 4 and challenge truck folks are running his gear, and it has proven to be very very durable. Chris |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 259 ![]() ![]() |
These 2 bearings are very important, A&S Fersa and NWB both had failures after 3-4 months if used hard, the original RHP's were OK but not great, they could still fail after 12-18 months but when these were no longer available we got our own made by NKE in Austria , to get these 2 made with their MOQ was £120K, we have not had one fail since we have had them, about 4-5 years, better than RHP by far, note the HD ones we fit are also NKE, Dave Dave |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 ![]() |
All sounds good to me Dave.
I need to call tomorrow & get one ordered. ![]() |
No not considered them Chris as never heard of them. Might take a look though. ![]() |
can Ashcroft supply HD output carrier bearing, as RHP bearing no longer available from LR and they are supply NWB 2515 BC 1410 £90.00 box marked made in chine and if you look at the roller on the NWB 2515 BC 1410 bearing 1/3 smaller so more point load |
Do you mean FTC2385 ? Dave
FTC3371 output carrier bearing
In the process of rebuilding my R380, order replacement FTC3371 output carrier bearing from LR and was send NWD bearing as a replacement, box had RHP RJ2022 fitted from new as far as I no. |
yes we have FTC3371 made by NKE which we find better than genuine RHP and way better than NWB or A & S Fersa
Dave Dave |
thanks
Can Ashcroft supply FTC3371, FTC2385 made by NKE ? |
